Question about Illy Francis Francis X8 1 Cups Espresso Machine W/ 35 Pods Mint
Illy iperespresso x8 knob won't turn - Illy Francis Francis X8 1 Cups Espresso Machine W/ 35 Pods Mint
Illy francis x8 service repair manual
Never found a service manual for a Francis Francis - I took mine apart by looking for bolts.
Jun 18, 2014 | FrancisFrancis! X1 - Stainless Steel...
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
Jan 25, 2014 | Illy Francis Francis X7.1 iperEspresso...
Illy Y1.1 leaking water
This type of fault is most often caused by failure of the hard plastic joiners used to connect the various water hoses within the machine - most commonly on the pressure relief device mounted near the outlet of the pump. Generally caused by the sharp vibration and build up of heat that characterizes most types of espresso machines. It is generally a specialised task to safely dismantle the machine to check them, but if you are able to do so it should be easy enough to locate the source of the leak once the casing is opened, although for preference it's better to take it to a repair shop
Nov 11, 2013 | Illy Y1 Touch Iperespresso Machine Brushed...
Lost nozzle on steam wand of Francis Francis x7
I did a quick search, and unfortunately, your only realistic options are to either fabricate yourself one, or try to get one via the manufacturer.
Sep 02, 2012 | Illy Francis Francis X7.1 iperEspresso...
My sony ericssion x8 won't receive message
Sir please check your Sms message centre. if you don't know the right no. then ask from the customer care.!!
Aug 10, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Illy Francis Francis X8 1 Cups Espresso Machine W/ 35 Pods Mint Logo
75 people viewed this question
Top Illy Coffee Makers & Espresso Machines Experts
ray gallant
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Illy Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
