Question about Sharp Office Equipment & Supplies
Find a user manual for the very old SHARP PC-2500
A user manual for the very old SHARP PC-2500 pen plotting calc.
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Need a user manual
You can purchase a manual from this WEB site.
Use this link.
http://www.9manuals.com/?gclid=CMP1ibvsmpsCFSRPagodggNUpQ
Posted on Jun 21, 2009
  • 102366 Answers
SOURCE: when i click graph it
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Sep 06, 2010
I just bought a Sharp Compet CS-2187 at a garage sale, but I don't understand all the switches at the top (e.g., DU CF/P.D, etc. I also am not sure how to set it so the decimal is always in place for...
Pam: I also have that calc. I also need instn manual for same reason(s). Works fine for 30 yrs old.
Did U get the User Manua?
Don deBruyn
daphrogue@bellsouth.net
May 31, 2011 | Sharp Office Equipment & Supplies
When i click graph it says "ERR: INVALID DIM" i noticed under "y equal" mode that plot 1 and plot 2 are highlighted. how do i fix this, i need to be able to graph. TI-84 plus calc.
Sep 06, 2010 | Texas Instruments TI-84 Plus Calculator
My calc doesn't graph. Once I click graph it says ERR: Invalid Dim, and my only option is Quit. What do I do??
If this isn't the problem, try posting the function(s) you're trying to graph, as well as the window settings.
Feb 07, 2010 | Texas Instruments TI-84 Plus Silver...
Steps from manual on how to do stemp plot box
To make a plot, first you will need to define a list. To do this, press "{", then enter the values of your list, separating each value with a comma, and ending the list with "}" then store (STO>) the list into a list variable ("2nd" + "1", "2", etc.). For a box plot, you will need only one list, and for a scatter plot, you will need two. One for the independent variable, and one for the response variable; that is, one for the X and Y axis, respectively. To make your plot, open the plot menu ("2nd" + "Y=") and select a plot. From there, you may select the type of plot and which lists to use as values.
To find the residuals for the line of best fit, from the home screen, press "STAT", then move one right to "CALC", then select option 4, "LinReg(ax+b)". Once this command is on your home screen, follow it with your X and Y axis lists, separated by a comma, eg: "LinReg(ax+b) L1, L2". Press enter. In a moment, you will be provided with 'a' and 'b' values. Plug those residuals into your "Y=" menu in the form "ax+b", replacing 'a' and 'b' with the residuals, and the line of best fit will be drawn across your graph.
Nov 11, 2009 | Texas Instruments TI-83 Plus Calculator
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
TI-84 Plus Linear Regression (ax+b) ERR:DIM MISMATCH
Some old configuration settings, or old variables are spoiling your fun. Clear the RAM and start again.
Hope it helps.
Sep 28, 2009 | Texas Instruments TI-84 Plus Calculator
When I press the y= key is comes up with a screen that has Plot 1, Plot 2, Plot 3 with u's and v's and w's with min's * max's. How do I get it back to the y= basic screen?
you might have it on the wrong mode. try going to mode, and see if the func selection is highlighted. If the SEQ is highlighted, it will show u, n, and min stuff. plot 1, plot2, and plot3 will show at all times anyway. there is nothing wrong with having them. You can always try reseting the calc. just remember to archive data
Mar 09, 2009 | Texas Instruments TI-84 Plus Silver...
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Could you help me
make sure your stat plots are off. you can just reset your calc. second + 7 1 2. or you can hit second y= and make sure that the stat plots are off. have any more questions. just send me a another request.
Jul 17, 2008 | Texas Instruments TI-84 Plus Silver...
Lag + Doesn't shut off... (ti84plus)
the I/O plot matters. If blowing doesn't help, insert a stick or something into it. I had the same problem, and my TI 84 plus had already been extremely unresponsive and slow before, as I fixed the latter problem by blowing really hard into the I/O plot, I did the same to fix the new problem. For many times nothing happened. Then I insert a metal stick into it and gently hit it inside. In a short while, the calc was normal again!! Now my calc even turns on when it's been put off, with its cursor frozen. I simply use my little finger to dig/scratch the plot and see the lovely cursor beating again. PS Having such a funny calc is really bad, but every time you fix it you'll feel good
May 27, 2008 | Texas Instruments TI-84 Plus Calculator
78 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
