Question about Intex Easy Set 530 Gallon Swimming Pool Filter Pump
The pump/filter combo for my easy set pool doesnt seem to be pumping any water. the pump runs but has no suction. not sure what it could be. any ideas?
  • 20 Answers
Prime the pump by filling with water BEFORE youturn it on.
Posted on May 07, 2009
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
Polaris 9300 Sport Robotic Pool Cleaner stops in water after running about 10 seconds.
Check your pool cleaners filter screen in the in-line filter system and make sure that it is clear of debris. Also check the skimmer, basket, pump basket, and pool filter to make sure that they don't have anything blocking suction. A loss of suction would definitely make the cleaner stop moving. Make sure that your hoses and connections do not have leaks that could be causing air to to escape.
Oct 10, 2011 | Polaris 3900 Sport Pool Cleaner ()
My pool filter pump will not self-prime after I change the filter.
Make sure the pump pot has enough water in it to make the pump **** the water up the suction line.there isn't anything clogging the suction line? Make sure there isn't anything restricting the flow of water to the suction
US Parts Center
Aug 21, 2011 | Sta Rite StaRite Duraglas Pump 1 12 HP...
How do i set up the vacuum for intake pool?
The first thing you need to do is make sure the pump is primed and able to draw water from the pool and return it with full flow to the pool. Now turn it off and make sure that your hose fits into the suction port and that the hose connects correctly to the vacuum head and the pool pole fits to the vacuum head. Next you need to disconnect the vacuum from the suction port and place the vacuum head with the hose and pole connected to it onto the bottom of the pool. Now force the hose straight down into the pool so it forces water into the hose and forces all the air out of the end that connects to the suction port. Keep forcing more and more hose into the pool until all the hose is filled with water. This is called "sinking the hose". The end of the hose can now be connect to the suction port. When the pump is turned on it should start pumping water from the hose into the pump and when flow is able to draw dirt as you move the vacuum across the bottom of the pool until it is clean. I hope this helps.
Aug 09, 2011 | Intex Easy Set Pool 15x36
Noted decrease in suction power and outflow. the first couple of uses this season the suction and outflow were notably strong. now there is hardly any force at all with the water circulating through the...
Remove the cartridge and see what happens with the flow. If the flow returns to 'normal' with no cartridge, that tells you the cartridge needs cleaning or replacement.
Apr 30, 2011 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
How do i change the sand in the filter? I am getting sand in my pool.
You will simply remove the old sand from your pool filter and follow the instructions from your users manual like you are adding sand for the first time. In case you don't have it, I am going to paraphrase it for you below.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
IMPORTANT: To prevent unnecessary strain on piping system and valving, always shut off pump before switching Filter Control Valve positions.
The correct amout of sand can be determined with this link: http://www.backyardcitypools.com/pool-filters/Filter-Sand-Requirements.htm
2. Set your controls to the backwash position.
3. Prime and start pump according to pump instructions. (be sure all suction and return lines are open), allowing the filter tank to fill with water.
4. Once water flow is steady out the waste line, run the pump
for at least 2 minutes. This initial backwashing of the filter is recommended to remove any impurities or fine sand particles in the sand media.
5. Turn pump off and set valve to RINSE position. Start pump and operate until water in sight glass is clear—about 1/2 to 1 minute. Turn pump off, set valve to FILTER position and restart pump. Your filter is now operating in the normal filter mode, filtering particles from the pool water.
6. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten connections, bolts, nuts, as required.
7. Set your filter to the "filter" position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
5. Adjust pool suction and return valves to achieve desired
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
Leaves in the skimmer line and its plugged
Is the obstruction on hte suction side or supply side of the pump?
Either way, you can disconnect the pump, and work from there. If the pump was installed correctly there shgould be unions ( fitting that can be reconnected on the pump suction and supply. If not, you can cut the pipes a few inches from the pump and then shorten the remainder to acomodate the length of the union. Glue these in place follow the instructions on the glue can.
Try using a water hose with the water on from the direction of the pump to the pool. see if this does the job. Leaves should be able to be pulled through by the oumop, I suspect somthing larger. Do you have a strainer on the suction line? Have you checked the pool filter?
I would check the filter first. Why do you think the problem is a clogged line? How do you know the pump is performing? Does it run a Spa, and nbot the pool?
\Good Luck
Mar 17, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Intex Easy Set 530 Gallon Swimming Pool Filter Pump Logo
595 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
