Question about Whirlpool Calypso GVW9959K Top Load Washer
Sears Calypso Washer purchased in 2004, displays the CA error code. Unplugged the washer for a couple hours and replugged in. Ran a cycle without anything in. Worked fine. Placed a load in and it ran for 10 minutes and then displayed the CA error code, again. Suggestions?
    Scholar:
  • 49 Answers
CA - Average Current peak - happens if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Overloading the unit may cause this problem. Try washing smaller loads and see if the problem goes away. If it recurs when you wash bigger loads, decrease the size AND watch to see if you have to continue to decrease the size to keep the error from happening. If that were occurring, it could well be a sign of the electrical problems noted, requiring service.
Posted on Jun 13, 2009
I ran a self diagnostic test on my Whirlpool calypso washer and got CA error code. Do I need to replace the drive motor?
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Before replace, I would first check the power supply, wiring and electronic.
Dado
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
We went camping for 2 days came home and the calypso washing machine won't start. We ran a load the day we left with no problems. The outlet works fine, we even tried plugging it into another outlet just...
The same happened with my Sears Calypso machine. The common problem is the front display panel. If you are able to find one at a very good price, post it here.
Aug 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer Stops/Starts when filling with water
Looks like part 8571359 the control electronics is out and guess what? Can only get through Sears and Whirlpool. This is why you cant get an error code, it isnt working well enough to choke one out. You know this is hard to say but a Oasis has its issues but at least it is still on market. I would if hubby is handy to find a used machine and pull the part. It is a chance but cheaper than 500 bucks to have a tech come out and fix.
Oct 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
CA - communications error
most likely suspect is the relay bd under console this is the one on left there is some kind of communication problem between the 2 bds
May 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Stuck at 7 mins left
sounds like you have a bad timer or check your belts
Nov 02, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
368 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
