Question about Whirlpool Duet GHW9150P Front Load Washer
How to remove front panel on whirlpool model GHW9200LQ
  • 249 Answers
SOURCE: rear shocks whirlpool duet GHW9200LQ front loading washer
press tabs inwards, at the time TAP the pegs holding the shocks in place.Get the hen to give you a hand .close IRE bye bye
Posted on Nov 24, 2007
  • 378 Answers
SOURCE: I have a whirlpool ghw9200lq front loader and its locked.
http://www.applianceaid.com/neptune3.html#lock
click the link directly  the brand is mytang in the link but the system is exact same and can be applied on whirlpool brand too. check out.
Posted on Apr 03, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer Model WFW9200SQ leaks
Removing the lower front panel would help immensly in determing where the leak is coming from. Most commonly, the leak is caused by the door bellow (gray rubber boot) leaking. If you pull back the rubber folds in the door seal and inspect around the perimeter, you may find that it has become ripped or torn. This is normal as they do wear out with age. If you determine the door bellow to be leaking you will need to replace it. The following link explains:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
The instructions to remove the lower panel are included in the link I provided. Another common symptom of a leaking bellow is the front counter weight on the drum will be wet.
If the bellow is intact, with no obvious signs of holes, check the water inlet tube that is located on the left hand side of the bellow to ensure it is fully inserted through the bellow properly. The inlet tube, if not inserted through the rubber correctly, will cause the water to run behind it and out the bottom of the cabinet. Push the tube through the rubber until it reaches the flange on the inlet tube.
Also check the following:
1. Check the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump.
2. Make sure the drain pump reservoir cap is secure and not leaking.
3. Check the along the seam of the wash tub as well. There is a tub gasket that holds the two halves of the tub together that can develop leaks.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 07, 2009
  • 20 Answers
SOURCE: how to remove front kick panel on whirlpool duet washer
just pull out the bottom it will un hook,,
Posted on Sep 13, 2009
heatman101
  • 43501 Answers
SOURCE: My washer is out of balance when spinning.
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 30, 2009
Testimonial: "Thank you. I think this sounds like exactly the problem I'm having."
Our Whirlpool Duet GHW9200LQ washer will not always start a cycle when you press the START button, although it does not give any error code. What's wrong?
I also have this problem. I removed the control panel, removed the green start button, put the control back together and pushed the red button on the panel and the washer works again. I just have to replace the start button.
Jan 22, 2013 | Washing Machines
My Whirlpool front load washer is out of balance when spinning. It makes a loud noise. How do I get the tub back in balance? GHW9200LQ is the model.
Whirlpool front load washers have shock absorbers that helps them in moving the washer around the place. Due to regular usage of the washer it may tend to break.This will result in drum hammering sound . To clear this problem pull the bottom front off and check the shocks. Typically the rings where the pins go through are where they will break. You have to grab them and should have a complete check by moving them to see that whether they are broken.
Thank you !!
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
The following link explains how to replace a door bellow:
Another method involves removing the washer top panel and working down through the top of the washer. The method I have described, offers the best open access, however. If you have questions along the way, please let me know. I hope you find this informaiton helpful.
May 11, 2009 | Whirlpool GHW9200L Front Load Washer
Apr 03, 2009 | Whirlpool GHW9200L Front Load Washer
Belt on Whirlpool Duet GHW9200LQ is broken
install belt onto motor pulley first then pull on side of belt onto spinner pulley holding belt onto pulley rotate spinner pulley until belt pulls onto pulley completly
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Order in clothes
Put a half a cup of vinegar into wash load, with soap. It removes the smells.
Jan 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rear shocks whirlpool duet GHW9200LQ front loading washer
ok its hard to remove the shocks without breaking the little tabs. You can tell which way they rotate out right?? There is a stop tab that stops the shock when its locked in. Rotate the other way, I use pump pliers (crescent wrench) and gently apply pressure until the tabs give. The new shock has new tabs and all..
Nov 24, 2007 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
