Question about No DigiTech RP355 Guitar Multi-Effects Processor
Can't access tuner - No DigiTech RP355 Guitar Multi-Effects Processor
How to activate the tuner setu
Check which input is the current one. You can't access the tuner setup unless the input is set to TV. There should be a Source or Input button on your original remote. There may be a matching button on the TV. Please add a comment with the model of the TV, if you would like me to check where the Input or Source might be. (If you have a universal remote, it may or may not match this feature with the code that makes most of the TV features work.)
Note: some TV models were sold without tuners or only NTSC (analog tuners) depending on their size and release date. ATSC tuners were only mandated in 2005 for 36"+ TVs in the US. For these older TVs, you may need an OTA tuner (or ATSC to NTSC converter) box.
I hope this helps.
Mar 29, 2018 | Pioneer Televison & Video
The antenna port is broke off on my lg flat screen tv how do i fix it
It's possible to resolder the port back on but the tv will have to be pulled down to gain access to the tuner and tuner cover will need to be removed to resolder the signal wire where it's broken off the tuner board. In some cases the tuner needs to be desoldered and removed to get access to the tuner board. If your soldering skills are not great an alternative solution would be to use an external set top box. This can be a pest because you then need a second remote to change channels.
Jan 14, 2017 | LG Televison & Video
NO TUNER ON PANASONIC RXDT75 BOOMBOX
Please press the [TUNER/BAND] button on the remote control to access the radio function of the stereo.
Apr 01, 2014 | Panasonic Audio Players & Recorders
Emerson EWF2006 TV access code
if your tv doesnt have a digital tuner, you cant, unless you have a digital to analog tuner converter (can be purchased in walmart, or other stores that carry tv s, electronics) you tune your tv to 3 or 4, use the converter box to scan for channels, and for changing channels instead of your tv tuner
Mar 21, 2013 | Emerson EWF2004 20" TV
I am unable to record digital tv channels on my LG RC389H dvd recorder. I have a new tv with a digital tuner and have hooked them up but unable to view any digital tv on my LG player only the old analogue...
The RC389H is only deigned to receive standard TV signals, not digital. If you are routing through a straight cable line you usually can't access anything above 100 if you don't have a digital tuner. Try using a cable/satellite box if you haven't already, this bypasses the requirement for a digital tuner because the cable/satellite box has one of it's own.
Aug 27, 2011 | LG Televison & Video
Tuner
the answer is yes. Once you get another tuner, simply use soldering iron to remove the old turner from the TV panel board and replace with another.
Good luck.
Apr 18, 2010 | Emerson SB350 13 in. TV/DVD Combo
Would like to have channels with help of an antena only
I don't think you can use an antenna only. You will need a DTV converter, as your VCR probably has an analog tuner (no longer usable), and your TV has no tuner at all. I believe you'll need to add a DTV converter and use the tuner in the VCR to switch channels. It will cost around $50 or so.
Dec 06, 2009 | Maxent MX42X3 42 in. HD-Ready Plasma...
FRONTECH TV TUNER MODL JIL-0606 CODE 10 DOESNOT START
How to configure Remote control in my TV tuner card Model No. JIL - 0606
Jun 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Wont load or eject
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
Jan 30, 2007 | Jensen VM9410 Car DVD Player
No DigiTech RP355 Guitar Multi-Effects Processor Logo
83 people viewed this question
Top No Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a No Audio Player and Recorder Expert? Answer questions, earn points and help others
