Blu055e936b1 Every time the fan (heater) turns on it makes a louder noise that normal
    Master:
  • 613 Answers
There could be a foreign object or debris touching the fan blades, or bad bearings in the fan motor. Open it up and take a look. See nothing, then grab the fan and try turning and shake it.
Posted on Dec 08, 2013
Laptop making loud fan noise like its overheating,
Go buy a can of compressed air and blow out the fans and vents. That should get it running quiet again.
Jun 08, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
When i turn my heater on (and also the ac) it makes a loud humming noise. as i turn it higher the noise gets louder. I have a 2001 chevy trailblazer.
It is possible that a stray leaf or piece of debris is stuck in the blower fan blades. This is more likely if the noise began suddenly. You will have to access the blower and remove it to inspect the blades. If their isn't an obvious debris problem, the blower fan bearing may be wearing out and getting noisy; although this noise would slowly get worse and worse every day.
Jan 24, 2011 | Chevrolet Blazer Cars & Trucks
Why does my electric fireplace makes a humming noise when on?
sounds like you may have a ceased fan get someone to look for you, but an electrical hum that is louder than normal usually means that the fan or a moving part is trying to turn ot move but can't so make's like a hum noise so seek a service agent
Dec 15, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Sharp winning or piercing compresser noise. is it normal? maytag refrigerator model # ptb1954grw.
maytag frig is noiser than other brands . amana also and jenair and majic . all made by maytag. this units have a compressor noise louder than most . there comp are larger and some what louder . but i would say you have a normal maytag .. mm i was maytag largest dealer in utah for many years and your statement is very common .. some times the copper lines or fans cause louder noises . so if to loud you should have ti ck'ed . mm
Aug 10, 2010 | Maytag Refrigerators
There is a noise that my heater makes when the heat is on. The heat still works, but as you turn it up higher , the noise gets louder. What could be causing this?
Probably some leaves or debris in fan cage. remove fan and clean. or it could be a bad fan motor bearing remove and replace.
Apr 20, 2010 | 2001 Jeep Grand Cherokee
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
Tempature flactuate most of the time. I have been told that main board is faulty
Check the CPU fan RPMS if they fluctuate over a wide range or the fan makes a louder then normal noise then the fan is probably going bad.
Jul 29, 2009 | Computers & Internet
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
