Question about Kodak EasyShare M583 Digital Camera
There is a circle within the lens and when I take pictrues, there is a white shadow circle in the pictures. How do I prevent this from happening?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
If the pictures taken are slightly misty, using a soft lens tissue (or spectacle cleaning cloth) wipe the lens delicately in one direction until the 'circle' has gone. Don't 'huff' on the lens as this will cause condensation INSIDE the lens.
If this fails to fix the problem, it may well be condensation build up inside the lens. If you have a sachet of silicone crystals (like the wee bags that come with a new pair of shoes), place the camera inside an airtight container with the sachet. Leave for minimum of 12hrs. This should absorbs any if not ALL of the condensation inside the camera.
Posted on Nov 26, 2013
I just purchased the Tamron 18-270 lens. When I take photos with the flash on, I get like a dark half-circle shadow either at the bottom or to the side of the photos. What could be causing this?
Lens is to long for the internal flash. Try an external one, it's position is more away from the center of the camera. Normally this should'nt happen, may be that the internal reflector of your flash is disorted.
Try to get a cheap 430 EX, more power, better light and with an radio controller usable as an unleashed flash. You'll get better pictures with flash a little bit far away from the camera angle.
Jan 25, 2011 | Cannon EOS 50D Digital Camera
When pictures are taken outside during the day they are unclear with some white horizontal lines and when taken indoors its ok.tried everything the manual said but still no changes
White shadow or white lines may occur if the light was too bright when you take the picture, especially in strong sun light. Have you turn off the flash light when you taking those picture ? If you haven't, then you should try to turn off your camera flash light manually. And I must remind you not to take a picture with your lens faced the sun light or other light (lamp etc) directly. Even if you take a picture outdoors, try to make your lens shaded by something, you can even use your own shadow to shade them.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Cameras
In certain lighting situations there are spots on the photos. Is there a way to clean the lens to remove these? I think its dirt on the interior lens
No not dirt, what it's called is lens flare. Lens flare is where a sharp/bright point of light enters the lens on an angle and causes the light to refract through the lens elements. This is hard to see happening on a pocket point and shooter and equally hard to prevent. What can be done is you hold your hand above or to the side of the camera out of it's field of view to cast a shadow on the lens and the flare won't happen. However sometimes you get your hand in the pictures. Even on my pro cameras and lens combination this happens even with the use of a lens hood. The good part of this is I can see it happening through the viewfinder. The only other thing I can suggest is to change either the angle of the camera or recompose the scene or subject to the point of light is not causing this flare.
Dec 28, 2010 | Pentax Optio W10 Digital Camera
Dark semi circle shadow and pics too bright
Are you using a lens hood? Is your ISO set too high?
Apr 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
Brown tint on photos with Nikon D 90
Or more properly, the shadow of your lens hood.
Aug 03, 2009 | Nikon D90 Digital Camera with 18-105mm...
Photosmart pictures have random white circles
It sounds like you have a photosensor that is going bad. If it happens 80% of the time, it is time to fix it or repair it. I have a friend who can fix cameras, he is cheaper and faster than the manufacturer.
http://www.cameradr.com/
Nate
Dec 21, 2008 | Nikon Coolpix S51c Digital Camera
I get a shadow when i use my flash, at the bottom of my picture. i'm using a nikkor 18-200mm 1:3.5-5.6 g ed len with the built in flash
this is most likely a shadow of the lens.  The only realistic way of preventing this is to use an external flash.
Dec 11, 2008 | Nikon D50 Digital Camera
Problem- head shadow on flash shots taken in auto
Is it possible that you shoot with the lens hood on?
If so, at wide angles you get a bottom shadow of the hood.
Jan 07, 2008 | Nikon D40x Digital Camera
White circles appear on the image. Why is that and what can I do?
When shooting with flash in a location where there are many suspended particles, such as in a dusty area or on a snowy day, the image may contain white circles as shown in the picture below. Why does this happen? If the flash fires when a suspended particle floats right in front of the lens, the reflection of the flash from the particle appears more intensely than that of the subject, as the particle is much closer to the lens than the subject. Therefore, the reflection of the flash turns out in the image and causes an effect such as that shown in the sample image above. The closer the lens and strobe are located, allowing suspended particles to be exposed to more light, the more frequently this effect can occur. How can I avoid this effect? Ideally, it is best to shoot in locations where there are very few suspended particles. If not, you can use following method to prevent this effect. a) Avoid using flash by lighting the area as much as possible. b) If your camera has a zoom function, shoot at a wide angle.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
White circles appear on the image. Why is That?
When shooting with flash in a location where there are many suspended particles, such as in a dusty area or on a snowy day, the image may contain white circles as shown in the picture below. Why does this happen? If the flash fires when a suspended particle floats right in front of the lens, the reflection of the flash from the particle appears more intensely than that of the subject, as the particle is much closer to the lens than the subject. Therefore, the reflection of the flash turns out in the image and causes an effect such as that shown in the sample image above. The closer the lens and strobe are located, allowing suspended particles to be exposed to more light, the more frequently this effect can occur. How can I avoid this effect? Ideally, it is best to shoot in locations where there are very few suspended particles. If not, you can use following method to prevent this effect. a) Avoid using flash by lighting the area as much as possible. b) If your camera has a zoom function, shoot at a wide angle. c) If you can attach an external flash, use the external flash to distance the flash from the lens.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Kodak EasyShare M583 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
