Psp turns on then goes back off - Televison & Video
Psp wont turn on, bought a new battery and still there is nothing? Thanks, Stevie.
When you switch the PSP on -- do you get a green light for a few seconds that goes back off? Or no green light at all?
Sep 30, 2010 | Sony PSP (Piano Black)
Ok,I dropped my PSP and evertime I turn it on,it goes to the "Sony Entertainment"thing,then goes to the moving wave background and stays that way.I have to remove the battery to turn it off.
Pull out the battery again and before you put it back on press and hold the select button. While holding the select button, go ahead and turn it on. Still hold the select button say 45 seconds after switching on.
Regards
Feb 24, 2010 | Sony PSP (Piano Black)
PSP
backup your file like game and savedata and music and picture on your PC hard drive to make sure you don't loose any important files
after that format your PSP Memory Stick then reset your psp on the early state on the PSP MENU Setting then put your backup files
or
update your firmware
or
still doesn't work bring it to PSP Repair.
it might be Your PSP Device might have problem let them fix it for you
May 14, 2009 | Namco...
Flicker and very slow
turn off your PSP ,then switch on again.. when the screen are in black condition "press R button" and change the CPU speed
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Go to psp recovery menu and set the CPU speed in XMD to default, it should work
My PSP turns off in middle of stuff
it may be a temporary glitch.try to do it several times and if it's really showing consistently the same glitch,then there might be either a disc game or psp hardware problem.try to play other disc games on your psp console,if you don't encounter any problems,your psp console may be out of the woods.or use your nba 08 disc on other working psp consoles and see how it goes...if you encounter the same glitch,most likely,the disc is defective.i assume you have an official firmware on your psp.hope this helps.
May 04, 2008 | Sony PlayStation Portable (PSP) Console
Psp will not load in any games
"tap" not hit.. the back of the psp, (where the game goes in on the back) and see if that works.. that will usually get the laser to read the disk.. perhaps the umd is dirty..  only tap on it "lightly" when you hear it loading.. i know that sounds stupid, but it worked for me countless of times.
Oct 31, 2007 | Sony PlayStation Portable (PSP) Console
Psp wont turn on
You really need to send you PSP into Sony for repair.  There is not much you can do with the porblem you have. Contact Sony repair at the listing below.
SCEA Consumer Services
1-800-345-SONY (7669)
Oct 09, 2007 | Sony PlayStation Portable (PSP) Console
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
