Wheelwriter 3
The bottom half of the letters and numbers is not picking up the ink.
The ink cartriage works in another #3 so we know it is the typewriter that has the issue.
Make sure that the ribbon is snapped down all the way. Also take the palms of your hands and press down on the platen (black rubber roller ) firmly and see if it clunks when you do it. Sometimes the platen can pop up slightly and this will cause the problem you talked about.
typing the top half of each letter
Donna, sounds like the carriage spool is stuck or out of adjustment. Not to hard, but pick up typewriter and slam it down on counter to see if it put carriage and spool back in position.
Good luck.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place. If the print is generally bad the plastic print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
I have solved the problem. It turned out that the platen was not completely secured on the left end. Once I snapped it securely in place, the print was fine again. (I had to remove that platen three times to figure that out!) Sorry for the bother, but I'm glad to know where I can seek help now. Thanks.
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
