Question about Toro Lawn Mower With Toro Power Tools
Oil Drain Plug Location
I have a Toro 550 rotary mower. I want to change the oil, but can't remember where the oil plug is located. I thought it was under the mower deck, and I found what I thought was the plug, a square slotted plug in which my ratchet driver fits, but won't turn. It this it or am I all wrong? Thanks in advance.
    Sergeant:
  • 201 Answers
That is the drain plug sometimes hard to get loose but should come out it is in bottom of engine above blade.
Posted on May 08, 2009
Where is oil drain plug for toro gts5 6.0 mower
The oil drain is under the mower deck. You will have to tip it up, find a pan or put it on blocks, and remove the plug.
Sep 26, 2014 | Toro Garden
Toro zx 5420 oil change
The lug is under the mower. There should be a square plug that is the oil drain plug. Disconnect the spark plug first then remove the oil drain plug. You should have the muffler facing up because oil will get into the cylinder and cause blue smoke when the engine starts if you don't.
May 18, 2014 | Toro Garden
Oil plug location
there is a drain plug on the bottom of the engine near the crank but it is faster to turn the mower on its side and drain it from the dip stick hole
Apr 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
there is a plug on the bottom of the mower above the blade but its easier to tip the mower on its side and drain it threw the dip stick hole
Put too much oil in toro lawnmower
Hi cldgaines1...
You do not want excess oil in the crancase, it can cause mechanical problems and smoke a lot.
Drain the excess oil out of the crankcase..
If you have an oil drain it will be located under the mower housing.
If you do not have an oil drain then you will have to tilt the mower with the oil filler plug removed to drain the excess oil from the crankcase.
Please take time to rate me.
Jun 27, 2011 | Toro Power Lawn Mower
How do I change the oil on my Toro Personal Pace mower? Do I need to remove some cover?
The oil drain plug should be under the deck. You probably have a bracket in the way that you need to remove. Once you remove the bracket you should be able to access the drain plug. Piece of advice do not cross thread the drain plug and do not over tighten it. You should only turn the drain plug 1/2 a wrench turn above finger tight.
Jun 15, 2011 | Toro Power Lawn Mower
Want to change oil. Is the oil drain under with a 3/8 socket drive drain plug ?
Hi lfancisco...
Yes the oil drain plug is under the mower, normally a square plug,socket drive to remove to remove the oil from the machine.
Please take time to rate me...Free answer
May 16, 2011 | Toro Power Lawn Mower
Where is the oil plug for changing oil in the Toro recylcer 700 series. I can't find it anywhere
Hi marybasrai...
Look under the mower to find a square plug/allen key plug and remove that plug will allow you to drain the oil from the mower
Free answer, Please rate me
May 07, 2011 | Toro Power Lawn Mower
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
736 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
