was working fine....tried going up the hill....felt like the engine was slipping or something.....so I put it into nuetral....rolled back down the hill....won't go forward or backwardswas working fine....tried going up the hill....felt like the engine was slipping or something.....so I put it into nuetral....rolled back down the hill....won't go forward or backwards
You can't post conmments that contain an email address.
try forcing the wheel to move get the ztr rear off the ground and try turning the wheel if dont but pump sqeeled you have a bad check valve or pump is going out i say bad check vale rebuild it
I'd go to the junction of the linkage and the transmission and check from there. The transmission will have a lever or some sort of protrusion connecting to the linkage. See if you can move the lever/protrusion by hand, even if you have to disconnect it from the linkage. If you can move it, try to find neutral and reattach the linkage and adjust it so it corrresponds to the indicator on the shifter. If you can't move the lever/protrusion it's internal to the transmission and you are out of luck unless you're up to cracking open the transmission.
Well it could be that the Master Sullinoid Cyllinder is not engaging the clutch. More than likely in my experience its not a good sign. if you know a good mechanic, I would suggest having them look at it and see what they recommend.
You dont want to have to get a new transmition and if the fluids in the transmition are low and this pressure plate wont engage, dont chance it.
A new transmition is upwards of $1700.00 just for the transmition.
look under the car at the gear box for the gear leaver to see if its moving when you try to get another gear,,if it dont move there is a fault in the gear selector not the gear box,,,
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Wants to go into gear but it can't.
