Question about HP Pavilion dv1000 Notebook
HP pavillon dv1000 keeps hibernating
I have a HP Pavillon dv1000 laptop which has been working fine for a couple of years. Suddenly since the last couple of days, it has started initiating hibernating and then hibernates. I initially thought that it was a battery problem, but even if I run it on AC mains, it hibernates after a random period of time.
I disabled the hibernate option under the power management, so it has now started to go into stand by. Any help would be appreciated
  • 1 more comment
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    here is the manitenance manual for ur notebook
    http://h10032.www1.hp.com/ctg/Manual/c00...
  • Shoaib Rais
    it seems to me that ur DV1000 notebook is going thru serious heat up issue which is quite often in HP DV series u can try cleaning the FAN Vent in the back of laptop
    or other wise it may be Inverter or CCFL backlight issue for LCD
    pls connect external monitor to see if it gets pic after it hibernates if that is the case then it is not hibernation it is something else
    but it is always good to clean heat vents and see if fan is working and mving or making noise
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Go into the control panel and into the power options.
    In there tell it not to shut off the display and not to put the computer into sleep mode, see if that helps the problem
Does the 2005 hp pavillon have a web cam?
Skype don't need a webcam to connect (i use skype and don't have a webcam).
Normally on a laptop you see it well on the upside of the screen
May 21, 2014 | HP Pavilion Computers & Internet
How do i turn on my internal mic hp pavillon 6000
Go to START->CONTROL PANEL->SOUND
Click on the RECORDING tab, click on the mic that you want to use. Click on the SET DEFAULT button.
Done.
Apr 22, 2010 | HP Pavilion dv1000 Notebook
How to remove line in HP Pavillon laptop screen free service
GUys! I FOUND THE PROBLEM! . i have a HP pavilion dv1000 windows XP I think the cause could have been many things. I solve the issue by using a different baterry charger/adpator. I have 2 exact notebooks, so i tend to switch their chargers, maybe taht was the problem, also i was in south america, where the voltage is diff 220v. I believe the charger with the problem was ruined during my trip? Who knows. But it work for me. The other sugestions here didnt work
Jan 16, 2010 | Computers & Internet
Hp dv1000 laptop i already check fun and replace it motherboard still keeps on hibernating just a couple of seconds. please help
You can configure or disable hibernation to do this got into control panel and open Power Options. The first tab allows you to configure your settings the last tab allows you to disable hibernation.
Jan 07, 2010 | HP Pavilion dv1000 Notebook
I have a hp pavilion dv1000 laptop and it randomly hibernates
Go to the control panel > Power Options, click on the hibernation tab and uncheck it. Click on apply and ok. Hibernation can damage older HP systems such as the DV1000 that is running XP, make sure it is turned off and also go through the power settings and change the setting for closing the lid on the laptop. Change the setting to "Do Nothing". This will keep your system from getting corrupt.
Nov 26, 2009 | HP Pavilion dv1000 Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Why isnt my hp g60 touchpad working keeps disconecting
My HP Pavillon dv6000 touchpad keeps disabling itself, randomly. I have to keep enabling it, any solutions?
Sep 24, 2009 | HP Pavilion G60-120US NoteBook
Hp pavillon zd open case
try checking if there are plastic locks that prevents from opening the case of your laptop. It may somehow be located on the side or the bottom of the laptop.
Attention: Dont force it to open it may break the lock..
Aug 07, 2009 | Computers & Internet
Drivers for my pavillon tx1000
hi
i would like to provide you the drivers link. please select the correct model number and enjoy the free download.
Thanks
Appreciate to rate as "fixya"
Apr 23, 2009 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
1,983 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
