Question about AOC e2752Vh 27" LED Monitor
Hdd installation failure - AOC e2752Vh 27" LED Monitor
I have a Sony VAIO VGN-NS20E laptop. When I start it the message comes " SMART Failure Predited on Hard Disk. Warning: Immediately back-up your data and replace your hard disk drive. A failure may be
Smart error, failure or S.M.A.R.T. has been tripped. They all mean the same thing. Your PC's HDD is dying, how fast? Nobody knows. So what it really comes down to is that you have a limited amount of time to access your HDD in more ways than your panicked mind can come up with right now. So until you can figure out a plan, the most important thing you can do is turn off your PC. Remember running your HDD is using up valuable time. So remove the HDD, Go get a reliable replacement (your HDD is dying) and install your favourite O/S. At this point I would suggest you purchase an external HDD enclosure so can hook up the old HDD and transfer back the important files.
Dec 18, 2014 | Sony Computers & Internet
Media test failure
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
So, if you have any USB sticks or attached HDD's that do not have an install image remove them and reboot.
If the HDD has an operating system installed and it still won't work after removing any USB storage, check that the HDD is functioning properly.
Jun 22, 2014 | HP Pavilion zd8000 Notebook
Copier reads e7-03
E7
Content HDD trouble
Detail
HDD connection failure
If the HDD responds an error or does
not respond for 30sec, it is judged as
an error. (Other than the system area)
Data abnormality in the file
management area (when the cluster
chain is broken)
Cause
HDD is not installed properly to the ICU
PWB.
HDD does not operate properly in the
ICU PWB.
ICU PWB trouble
Check and
remedy
Check installation of HDD to the ICU
PWB.
Check connection of the harness of
HDD to the ICU PWB.
Use SIM 62-2, -3 to check read/write of
HDD.
Replace HDD.
Replace ICU PWB.
Aug 05, 2011 | Sharp MX-2300N Color Copier
HP compaq NX9420 fails to boot up; complains about system disk and i tried to install Windowsxp but it switchess itself in the process of installation
Hello Dear,
If you tried to install the windows XP on a failure HDD then it will behave like this.
You need to check your HDD first, Go to your BIOS and run the HDD Self test.
If it successful then Just format your HDD before installation it should work.
If it failed then you need to replace your HDD.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 11, 2010 | HP Compaq nx9420 Notebook
How can i solve the disk boot failure?
For Disk Boot Failure, below are the steps:-
1) First check your HDD. (Go to BIOS > Run the HDD self test).
2) Make sure there should not be any external media connected to your notebook (CD, USB drive etc.)
3) If your HDD is OK, then You need to install the OS again.
WIth regards
FIXYA
Sep 24, 2010 | ASUS Computers & Internet
I've got BIOHD-3 NO BOOTABLE DRIVE (HP Diagnostic test)
if it cant detect ur HDD ... then check for jumper settings. ...
Jul 04, 2009 | Computers & Internet
After fdisk and format of hdd install of os freezes after 2min. when it says windos is starting, tried differant versions of windows does the same thing!!!! Please help!!!!!!
PXE media failure means the system is trying to boot via Network card not your hard drive. When you performed fdisk then formatted the disk, you might have not selected an active or logical partitioning to support the OS. Run the PSA diagnostics by holding the Fn button before turning on your computer. If it gives you an error, it means your HDD has gone bad and needs to be replaced. If it freezes during the the loading of files during the installation, it means that your RAMs are bad because the windows loader dumps all the information to the RAM chips. If it does hang during the installation of files, two points of failure are to be looked upon, the RAMs and the HDD. I recommend you reset the BIOS to the factory settings as to reset the boot priority so it does boot to HDD first, not to any of the bootable drives available on your computer.
May 15, 2009 | Dell Inspiron E1405 Notebook
Ecs 945p-a install hdd sata
Choose in bios the setting about HDD. Choose Enhanced Sata compatibility. Now you can plug4 satas
Sep 23, 2008 | ECS 945P-A (V3.0) Motherboard
Can't start up the laptop as Media test failure
You may have to go back into the bios and see if there is an option to automatically find HDD, or you may have to manually enter them in the Standard Bios Settings. It may be that the old HDD are still in the bios's recognised setup.
Dec 13, 2006 | BenQ Joybook 5100U Notebook
AOC e2752Vh 27" LED Monitor Logo
70 people viewed this question
Top AOC Home Security Experts
Lawrence Oravetz
Are you an AOC Home Security Expert? Answer questions, earn points and help others
