Question about Intel Motherboard
RAID Driver sometyms..my pc gets restarted after showin a blue screen "Dumping physical memory"...i got to knw frm the log file that my RAID driver is not installd...how do i install it....i have tried the mother board cd but in vain....I have a MSI MotherBoard
  • nezam Oct 19, 2007
    This is nezam
    I have the Original cd
    But My System does not detect the installshield file,,,i have SATA hard disk...i dunno if i have problem with my RAM...but lemme be sure...can u tell me how to install RAID???
    i dunno i have prob wid ma RAM but i m sure abt the RAID Driver Prob
    I have The Original Cd
    But my system Does not detect the req Install Shield File....in the autoplay screen all other drivers are shown installed...but it does not talk abt RAID...Plz Help!
  • 1,006 Answers
It can happent for 2 reason :
1) You have a problem with RAM MEMORIE OR
2) U need to install driver for HDD ( raid driver )
U should olso dust Power Suply and Cooler onto procesor!
To install Raid driver u need to have ORIGINAL CD OFF MOTHER BOARD .If u haven't tell me i will help u!
Posted on Oct 11, 2007
HP TouchSmart IQ518a Desktop PC cannot boot up after Blue Screen Error
check the ram memory if it restarting in a loop ..when it gives memory blue screen is not referring on hard disk only ..it may be teh ram memory as well ..and if it had errors it is probably something wrong with the way you installed or the partitions you have ..You need a large C drive partition made for windows & ..at least 50 G and you need to format it when you install so that it is clean and functional ..If you installed over another OS..or not formatted it or it is too small ..even if you have space in other partitions this is not a solution ..You need to have space in C drive where the windows works ..
Other issues ... maybe is a file missing and does not let it boot or ..you made changes in BIOS .. for example if you installed the OS on a sata hdd ..and it was non raid ..and after that you defaulted the BIOS settings ..you may need to check the sata bus and see how it is set .. and probably need to reinstall the operation system ..If you want to use it with raid ..set it before installing ..and make a large C drive for it to work cause windows alone will have almost 20 g after first update .. Also download and put the raid or ahci driver on a usb stick in case it will ask it (will not see the hard disk on raid without driver ..even if the windows 7 usually it works cause it has the driver on install..)
So ..check BIOS .. and see if it loads teh operation system when you put the hard disk sata on non raid or on compatible or on native .. it may be presented differently but the idea is teh same to disable ahci or raid for the hard disk ..and save changes and exit ..After that may work ..Also remove and reinsert ram memory and see if there is something wrong with it..and the last action reinstall cause a file from the boot sequence may be lost and this is the cause for not starting .. it happens when you do not format teh disk and it has an error on it .. For the other drives and partition ..it may be enough to make a defragmentation ..for now if you have files on them and you install only the C drive ..
Let me know if you still have problems with t ..
Jan 24, 2012 | HP TouchSmart Computers & Internet
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
Mystery blue screen won't let me log on my computer!
IF U CAN GO INTO BIOS GO IN BIOS AND CHANGE FIRST BOOT ORDER TO CD ROM THEN PLACE XP CD IN CD ROM AND RESTART PC. AND REINSTALL WINDOWS..........
Jun 09, 2009 | Alienware PC Systems Alienware Aurora High...
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Restart pc ...when work is going on suddenly appear blue screen
This happens sometimes, but it's not very common.
Did you update any drivers recently?
Have you added any components to the computer just before this started?
You may have a faulty memory "stick". This is a link to Microsoft's Windows Memory Diagnostic. Follow the instructions to create a bootable CD, boot the CD and let it run and see if there are any errors.
Feb 07, 2009 | Intel DG31PR Motherboard
2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Apr 16, 2008 | Acer Aspire 3680 Laptop
Game troubleshooting
Hi. memory dumps like that are mostly always hardware (or drivers) related. If you haven't changed any drivers recently then it's probably hardware. My recommendation would be : 1) In the startup option of Windows (right click My Computer, advanced), disabled the automatic reboot upon memory dump
2) Next time you have a blue screen , identify the DLL or SYS file in the message. if it's always the same element that crashes then you found your problem. Google the driver name and see what is the problem. If you see almost random DLL or SYS files in your blue screen then you have an overheating issue (90% of the time it's the reason) or a simple hardware failure. (pain in the a** but these things happen) also, that doesn't mean the data is gone, but chances are if you can't boot at all ever again with the laptop you'll have to hook it's drive as a slave on another computer and get your data back. BUT keep in mind that the problem you are describing is NOT a HD issue or you would get the typical "NO HDD detected" or "No bootable OS found" post post-test issue. hope that helps !
Feb 22, 2008 | Computers & Internet
Physical dumping memory...
Try to increase your virtual memory.  This may help you some.
Oct 27, 2007 | Computers & Internet
Missing file
you have a corrupt driver, try a system restore to a day before this happened as you may have updated a driver which is not compatible from microsoft with automatic updates, or it's because of software that has recently been installed
Sep 16, 2007 | Microsoft Windows XP Professional With...
Intel Motherboard Logo
105 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
