Question about Samsung Refrigerators
My Samsung RS2544SL refrigerator is no longer cooling either the refrigerator or freezer compartments. The interior light is on, the there is only one segment blinking on the control panel, and the ice chute closure door is open. I've pulled the wall plug twice and reset it hoping the refrigerator might reset itself. Is there any reset function for this refrigerator or does the control panel have to be replaced to get the refrigerator working again? How difficult is replacing the control panel if that's the problem Thanks for your time! Dave
  • 749 Answers
SOURCE: Whirlpool Refrigerator Model No. WRN28RWG6
if the flap was open then truely excessive cold air is coming out/escape from the freezer causing no freezeing. you need to defrost your fridge.
Note also that frost build up increases time to freeze your food on the freezer. it also causes your fridge an increase in electricity consumption.
defrost your fridge for some time ti remove the frost build-up.
Posted on Nov 19, 2007
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
SOURCE: Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had the same problem. One morning I opened the doors to a hot fridge and burning plastic. The light housing was sizzling hot - much of the unit literally melting away. Another hour or two and it could have been much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes of patient talking, I learned that Sears (or Kenmore) have issued what they refer to as a "flash warranty) on the light fixture kit (Kit # 6871JB1423N) which in effect, for this part only, extends the factory warranty from one year to three years. I may even be able to have a factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
Posted on Jan 13, 2009
SOURCE: Error Code ER FF
I had the exact same problem with my LG refrigerator. You need to follow the instructions of the person who posted solution #8 (simply unplugging the refrigerator does not work or is a temporary fix). You need to empty the freezer and remove all the railings (including side). Then you will have full access to the inside back wall. Next you need to remove the screws to the inside back wall and gently remove the back wall being careful not to break the wires connected to the fans. Here you will find a massive amount of ice buildup which is causing the problem. Once you remove the back wall you will be able to remove the ice and everything shoud work. Note: All you need is a screw driver and time. I paid a lot of money for this refrigerator and it has been one problem after the other.
Posted on Jun 05, 2009
SOURCE: Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light show last night. Followed instructions above to disable it, which temporarily solved the problem. Was on the phone with Maytag (Whirlpool?) this AM, and their initial response was that they wouldn't cover anything since we are out of warranty. I had to be extremely firm with my expectation that all parts and labor would be covered. Sent the rep back to her supervisor several times until they agreed to cover both. If you find yourself in a similar situation, don't give up until everything is covered. This is a design issue that should NOT be impacted by an expired warranty!
Posted on Apr 15, 2010
Samsung RS2544SL/XAA getting iced and freezing
In freezers if it's getting ice inside body surface? Sometimes refrigerators doesn't defrost ice completely and shut the drain water line of defrosted ice. If you doesn't have checking instruments for defrosting heater element and other parts, there id's wary wary to defrost ice once completely once. Thank you
Oct 17, 2016 | Samsung Refrigerators
Water is no longer coming out of the water dispenser. The fridge is plumbed in and water is getting to the water filter and the ice maker but not coming out of the dispenser.
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Jul 16, 2008 | Samsung Refrigerators
Why is my haier refridger not getting cold
There are alot of things that can cause no cooling...
a stuck tstat, will cause it to freeze up(electronic control)
a broken defrost timer will cause ice build up from no defrosting
out, or low on freon charge
inefficient compressor
door gaskets leaking
light switch not cutting off the light inside the cooling or freezing compartment
a bad fan motor(door) switch
I dont know how your unit works, but most only have one evaporator in entire unit..and its in the freezer compartment, and the cooling side gets it (coldnest) from the freezer compartment..with a door flap that alows cold air from the freezer to enter the cooler side.
Hope this helps..
Jun 04, 2014 | Samsung RS2630SH Side by Side Refrigerator
MODEL RS2544SL NOT COOLING
Do you see ice on the back wall of the freezer?
Feb 02, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
My samsung ref (top freezer) does not cool well in the lower compartment but the freezer is fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Samsung Refrigerators
The fridge compartment in my Samsung side by side fridge is not cooling, yet the freezer side is perfect. Any ideas?
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 21, 2010 | Samsung Refrigerators
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
Jun 12, 2017 | Samsung 24.8 Cu. Ft. Side-by-Side...
Temperature on screen : for frezer39 for refrigerator cool 56 Samsung Refrigerator RS2544SL
Check to make sure evap fan is working, you should be able to open freezer, push in on door light switch, wait a second or three and see if fan comes on, you will be able to hear it if it does.
Check also that you don't have frost/ice build-up on back wall of freezer. If you do u have a defrost or cycle problem.
Oct 01, 2009 | Samsung Refrigerators
Refrigerator Compartment not cooling properly: freezer compartment working properly
Check the freezer section for frost build up, there is probably a problem with the defrost cycle. 1 of 3 things defrost bi metal would be the likely problem.The back panel in the freezer should be removed to see if there is too much frost.
May 01, 2009 | Frigidaire FRT18S6AW Top Freezer...
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
258 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
