Question about Kirby G6 Bagged Upright Vacuum
Kirby g1 drive belt replacement - Kirby G6 Bagged Upright Vacuum
2 Suggested Answers
  • 27 Answers
SOURCE: The belt on my Kirby G3 wore out, and I bought
kirby has only had 1 belt from day one. sometimes you do need to push the belt up to catch the belt lifter
Posted on Apr 23, 2010
Kirby G10D not driving on assist. every thing looks good when in gear turning the wheels the transmition does not turn Why?
First thing to check is if when pushing pedal it moves gears located on the rear Kirby transmission axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken. If it is then just replace entire set to make sure that belt type matches gears and the set is not that expensive
Last and the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission ) Kirby Transmission Troubleshooting
800-775-6586
GoodVac com
Feb 22, 2015 | Kirby Vacuums
How do I replace the drive belt on a kirby G4? Actually the belt is already replaced I just need to know how to reattach that front part back onto the main vacuum. HELP
Greetings from GoVacuum,
Here's a video we shot showing you in detail how to install a belt properly, and how to reattach the head properly. I hope this helps you;
Jan 30, 2010 | Kirby G4 Bagged Upright Vacuum
How do I replace the drive belt on a Kirby G5 vacuum cleaner?
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners including your Generation 5 (G5). The belt change procedure is the same for Kirby Models G3-G10 Sentria. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Thanks for watching!
Chris J
Jan 20, 2010 | Kirby G5 Bagged Upright Vacuum
Vacuum not sucking up dirt
It could be a belt. Also make sure that you have correct hight adjustment. For instructional video look HERE.
Good Luck,
Rocky
Nov 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
REPLACING BELT KIRBY CLASSIC III
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=806061
Posted by JETALBOT on July 19, 2008
I CAN'T REPLACE THE BELT ON THE CLASSIC III (KIRBY). CAN YOU HELP ME? ELAINE
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 19, 2008 | Kirby Heritage II Vacuum
Belt
I don't know where near you, but most local repair shops should have the belts for kirby.
Jun 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
23 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
