Question about Miele 3.7 cu. ft. / 105 liter Upright Freezer F623UI-2
Bottom drawer hard to close
The bottom drawer is very difficult to close. As you open it the drawer falls to one side and then you have to lift it to close it. My old freezer which was the same model didn't have this problem.
  • Miele Master
  • 4,655 Answers
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Posted on Oct 24, 2007
SOURCE:
Frigidaire bottom freezer spills ice when opened and I can't shut the drawer til I fish the ice cubes out.
You might be well served with a general defrost of the unit. But before you do, make sure that the mounting screws on the ice maker are fully in. Then if so, warm the lower surface of the ice maker where cubes are ejected with a hair dryer for a minute or two (medium not high). It could be that extraneous ice is catching the cubes. What does it feel like to the hand?
Mar 02, 2018 | Frigidaire 20.3 cu. ft. Upright Freezer...
Kenmore freezer drawer frozen shut
use your wife's electric handheld hair dryer as close to the rails as you can once slightly open you can use table salt/ice melt to free the drawer or; turn up your house thermostat to about 80 degrees for the day while you are at work; the drawer should be free by the time you get home.
Nov 18, 2013 | Freezers
My amana bottom freezer drawer keeps rusting over making it difficult to open and close. i have cleaned it several times and used various lubricants which work for a little while, then rusts up again.
It sounds like you are having a condensation problem. Is your freezer fully sealed? Is your refrigerator turning on and off and not staying on as it is supposed to? You can tell by putting an ice cube in the freezer and seeing if it melted, or melted and got frozen again.
Oct 16, 2013 | Freezers
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Hotpoint FFS70 freezer door won't close
there must be a basket that is bent ,
Jan 18, 2008 | Freezers
Miele 3.7 cu. ft. / 105 liter Upright Freezer F623UI-2 Logo
235 people viewed this question
Top Miele Freezers Experts
Jay Finke
Jay Finke
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Miele Freezer Expert? Answer questions, earn points and help others
