Question about Garden
I have a Troy-Bilt PTO Horse (Horse III) 8HP TINES
I have a Troy-Bilt PTO Horse (Horse III) 8HP Electric - bought new 1987.
The man who bought it is dead, but it has a really good looking set of tines on it with the original tine hood; however, when you use it, it sligs dirt everywhere and you hear dirt/rocks striking the tine hood.
I wonder if he put too large/long tines on it. I cannot find the specifications/dimensions for the tines that are supposed to fit the tiller. I don't want to order a new set of tines to just check the dimensions of the existing ones.
I need the measurements of the tines that fit it.
Like:
1. the thickness at the heel end (where the
bolt holes are),
2. the width at the heel end where the
bolt holes are),
3. the distance from the heel to the tip of
the tine (the hypotenuse.
Thanks,
Donald Cox
  • 86 Answers
The tines are very close to the housing and sometimes you do get rocks hitting,as for the dirt it should have side panels to keep the dirt in place.
Posted on May 13, 2009
I have a 1988 troy bilt horse 8hp the tines rotate when its engaged or in disengaged
check the shift linkage sometimes the pins fall out when you shift it does it move to freely
Apr 19, 2012 | Garden
Troy built horse loses power when I engage tines into the dirt. What do I need to service?
sounds like you are trying to till too deep raise tines up a little with the depth gauge then till the same spot again and see if that helps
Mar 10, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
New tines now gets away from me
double check to make sure you have the new tines in the right direction. also you could try to raise your machine, as the new tines are digging better it might not have to be as low as you had to go with your old ones.
Mar 25, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
May 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
498 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
