Question about Little Tikes Fold and Store Picnic Table
How to fold down - Little Tikes Fold and Store Picnic Table
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
I have a 2003 chevrolet tahoe how do I fold The seat down
The second row is folded by first pulling up the rear of the seat cushion and folding up 'til it's behind the back of the front seat. Then the back of the seat folds down where the seat cushion was.
The third row seats have several levers that are numbered in the sequence they are to be operated. First fold the seat back down on to the cushion and then flip the whole seat up 'til it's vertical and latched.
This is described in the Owner's manual if you can find one.
Mar 15, 2015 | 2003 Chevrolet Tahoe
2nd Row Headrest Stuck in Upright Position and will not Fold for Stow n Go
You will need to take the seat apart to determine what is not fastened to release it.
Apr 09, 2014 | 2011 Chrysler Town and Country
Stylus - Morocco Travel System Stroller: how do you fold stroller down to fit into car?...
please help me i really need your help on how to fold it down i am only 9 and i need to fold it down . i have this pram cause i have a dolly called sophie
May 05, 2010 | Graco Stylus Morocco Travel System...
2003 Toyota Corolla LE back seat fold down? how?!
Open the back trunk, look near the top of the trunk, and pull the two black levers. They have a seat folding down symbol. That will release the locks to fold the back seat down.
Jul 03, 2009 | 2003 Toyota Corolla
Just got an 2002 Chrysler Voyager. I can fold down the rear bench seat using the black lever on it but can't find a lever, or other release device to fold down the middle bench seat. How can this seat be...
i dont think they were meant to fold down but you should be able to take them out to haul bigger items. some of the vans they make are made that way so that you have to remove the seats rather than fold them down
Dec 06, 2008 | Chrysler Voyager Cars & Trucks
How to fold down back seat
There should be a loop between the seat and backrest, pull that and the seat will pull toward the front seats. After that, pull the lever located at the outside of the backrest. This lever is on the outside of the seat by the door-side of the seat. Pull that up and allow the backrest will fold down and the headrest will pivot back and your seat is folded down.
Jun 28, 2008 | 2004 GMC Envoy
Rear seat won't fold down (60 part of 60/40 seat)
I had the same problem on my '03. The seats would not fold down using the latch release as I had always done. So I tried a combination of pulling up on the side latch AND the top latch and the seat folded down. It really doesn't FIX the problem but circumvents offending  defective part. I will use this method until it doesn't work then I might shell out the $$$$$ to the dealer.
Jun 18, 2008 | 2003 Honda Pilot
Little Tikes Fold and Store Picnic Table Logo
80 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
