Question about Panasonic TC-32LX60 32 in. LCD Television
Panasonic 32" HDTV keeps turning off
Recently my TV will work for a short time and then turn off.  The power (red) light starts flashing.  I have to unplug the TV, plug it back in and then it works for a few minutes then will turn off again on it's own.  Anyone have any ideas?
  • 8 more comments
  • 1tonyp Dec 02, 2007
    Panasonic TC-32LX60 32" LCD Keeps turning off. Unplug the set and replug and the set will come on for a few minutes and turn off again.
    Anyone have a possible solution?
  • Drugs Jan 21, 2008
    same problem ...man this sucks anyone see how much it might cost to fix or any other info please post thanks
  • Ishmole Mar 29, 2008
    Same thing.....doesn't anybody have any ideas?
  • Crossword Apr 22, 2008
    Turned on TV, and it shut down. No picture or sound and the power light flashes slowly. Power switch has no affect. About a year old with no previous problems. Pullin plug had no affect.
  • pixchick Apr 24, 2008
    same problem - no power, but red light flashing. this problem started after the television hadn't been used for almost two weeks. any ideas yet?
  • Anonymous Dec 25, 2008
    I actually have the TH-42PX75U, but its doing the SAME thing as everyone else's TV's.
  • cycomonki Jan 16, 2009
    I have a Panasonic TC-26LX60. I have had it over a year. I went away for a week and just got home and it won't turn on. The red power light is flashing two times. It won't turn on at all. :*(
  • Anonymous Mar 24, 2014
    My 32" toshiba TV has I found there was no red light on the TV. I tried to unplug and re-plug, there was no power come to the TV set. Any suggestions?
  • Anonymous Mar 31, 2014
    Proscan 32 inch tv Keeps flashing different colors won't turn off unless unplugged
Check or have a repair tech check connectors AP1 and AP2. Vibration rattles the power supply board (a crappy design, as the board is almost "floating") and causes the wires in the connectors to break, and may make intermittent contact. Heat may also cause intemittent contact. A very common flaw.
Posted on May 06, 2008
I just purchased the TH-42PX75U. It would run fine for an hour, then shut off...I would unplug and re-plug..same story. After much chatting on Panasonics Help chat option...7 blinks means there is a component that is not operating properly. Seems to be a common problem with this particular TV based on my online research. Anyone have any suggestions to make it easier to put this thing back into that box??!!
Posted on Jan 29, 2008
SOURCE:
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Starting light flashes green, and then red. Turn off and on several times.
Possible lamp but:
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 07, 2012 | Mitsubishi WD-65733 65" HDTV
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My TV will not turn on. Power light is blinking
my 32" panasonic lcd t.v will not turn on but the red light keeps blinking in front?
Oct 12, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Panasonic TC-32LX60 32 in. LCD Television Logo
1,152 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
