Question about Canon Office Equipment & Supplies
My copier is saying remove paper when there isnt any paper jam
There is no paper in the out tray but it keeps on indicating that i need to remove paper
printech
  • 159 Answers
SOURCE: HP 4350n Printer says paper jam .
check the paper sensor maybe one of the sensor stuck
Posted on Mar 17, 2008
  • 37 Answers
SOURCE: keeps saying no paper in tray although paper is in tray
I encounter that problem before, after I checked the sensors, feed unit and mechanism nothing is wrong or broken but still NO PAPER indicates on the display .I only noticed with the machine is the cassette tray or the paper tray, when you try to pullout the cassette tray and look at its left side, there is missing parts on it. There is a spring and actuator on it that will engage on the feed unit drive. Try to find the same machine and look at the cassette tray to see the missing parts on it. You can buy a new cassette because the parts that is missing maybe not available.
Posted on Feb 27, 2009
tehnik_bdg
  • 91 Answers
SOURCE: Sharp printer copier MX 4501N, how to remove the
Pull the paper tray to the front, after it is stuck pull it up ward and front
Posted on Apr 16, 2009
  • 214 Answers
SOURCE: Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
Posted on May 04, 2009
bootz84
  • 197 Answers
SOURCE: Oki B4540 keeps saying
You should certainly start by looking at the toner cartridge to see if there is any tape to remove. If there is no tape with a visible pull tab, check inside the printer to make sure that there are no pieces of torn paper stuck anywhere inside.
Posted on May 05, 2009
Hp 2515 no paper on tray but indicating fake paper jam
May i know the printer model # / name ( full ) to assist you better. ?
Mar 24, 2014 | HP Officejet Pro L7680 All-In-One Printer
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 11, 2009 | HP LaserJet 4050 Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
KEEPS SAYING PAPER JAM AND THERE ISNT ONE. DOESNT SEEM TO WANT OT PICK UP PAPER
ok im going to guess here that you are getting a 201 paper jam error with no paper in the printer. this would indicate a bad main motor drive replace it.
if its a 202 error check the 2 sensors on the fuser for stuck flags
if its a 241 error clean the pick wheels with aresol elctronic contact cleaner to remove the glue build up from them. or replace them
Dec 04, 2009 | Lexmark T640 Laser Printer
Kyocera FS-920 RED LIGGHT IS BLINKING AND GREEN LIGHT IS OFF
There are 2 possibility to cause your printer acting like this:
1) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
2) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
If it is condition 1) then just remove the jam paper then open and close the Top Cover to clear the error.
If it is condition 2) then insert some paper in the paper tray.
YBC (/\)
Jun 05, 2009 | Kyocera FS-920 Laser Printer
Printer says "Remove paper jam"
check that the paper tray is set to match the paper your printing - look also in the printer driver settings for the correct size. A4, Letter etc.. If that did not fix it make sure the paper take-up roller isnt worn.
Jan 20, 2008 | Office Equipment & Supplies
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
11 people viewed this question
old marine
old marine
