Question about Acer Aspire One PC Notebook
Acer One pc notebook black screen?!
I turned on my laptop, and a black screen with a bunch of letters that looked like codes, similar the boot menu, came up for a little bit, then the screen just stayed black. i had to manually shut down the computer. i let it sit for a while, but when i turned it back on, the same thing happened and the screen just remains black like when its off. you can hear the computer running, but the screen just stays black. what should i do?!
  • seapro2004 May 08, 2009
    I have the same exact problem. The computer starts and the screen stays black? I've only use the mini laptop a half a dozen times since Jan '09. Very Bizzare. FWE
  • martin_delga May 08, 2009
    thanks for anwering, what and where do i download the BIOS, how do i format it with FAT?
    Problem Solver:
  • 10 Answers
That is a problem of BIOS. U need to reset your BIOS.
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
Posted on May 07, 2009
  • PrimeZ
    PrimeZ May 09, 2009
    To format yourd disck to FAT insert it into your USB port
    open my computer, right click on on the Flashdrive icon and choose format(make shure you don't have any data on your flashdrive or you will loose it)where it sais "File system" change it to FAT or FAT32. Press start and you sould be oukay.
    You can download the BIOS from here:
    http://sites.google.com/site/maclesblogs...
    hoose any of the bios(I recomend 3307)
    Good Luck!
The screen on my acer asire/E won't turn on even though it is powered on.
could be what they call the inverter thats gone..or your screen has gone..to find out if its your screen thats faulty just put another monitor to your laptop using a vga cable ,if your windows show on the monitor then its your laptop screen or the inverter thats gone.
Apr 20, 2014 | Acer Aspire One PC Notebook
Comp turns on and goes to black screen with cursor
could be a ram error or...... hit f8 right after the boot screen to get the windows menu and then try to boot into safe mode..... a hard driving thats going bad can cause this error to
Oct 13, 2013 | Acer Aspire 5520-5908 Notebook
Aspire One PC Notebook Your question about Aspire One PC Notebook has been posted. Whats wrong with my Acer Laptop when i turn on its black with white letters saying PXE-E63:Error while initializing
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 15, 2012 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 5349 won't boot
I had the same problem. I clicked on F2. in Bios screen I press f10 (save and exit), and windows started.
Apr 02, 2012 | Acer Aspire 9300-5349 Notebook
My netbook won't turn on, it will get to the black acer start up screen, then the screen will go black for a while and then it will go back to the acer start up screen again... I tried pressing f2 to see...
when you turn on the Acer Netbook... Continuously press F8 until you see a Menu... from there you can do Start Up repair, or what i suggest is boot to last known Good Configuration (this Menu is known as the Recovery Console)
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Travelmate 4000 Won't Load HELP OHMYGOD.
when you boot up next time tap the F8 key. This will bring you to a screen that gives you a bunch of boot up options. Choose the one that says use last known good configuration. this should solve your problem.
Please remember to rate me.
Feb 01, 2009 | Acer TravelMate 2300 Notebook
Laptop starts to boot then screen goes black
when the windows are going in the booting and it is colored black, the problem can be wrong with the windows or set the mode dual setting LCD 1st graphic assign it, try to use external LCD Monitor or connect to back of laptop
Dec 14, 2008 | Acer Aspire 3680 Laptop
HP Pavillion ZV5405 with Black/White vertical lines through screen
Will it boot from a CD/DVD? Make sure the boot sequence is set to boot CD first and then see if it will boot into setup from a CD/DVD. If it will, then maybe try reinstalling windows. Hope this helps.
Aug 21, 2008 | Acer Aspire 5100 Notebook
My computer's "driver" won't start therefore my computer won't boot.
While Booting the Laptop, Press the F2 Key (some use DELETE key) .. THis will take you to your Bios Setup.. Look there for .. LOAD OPTIMAL SETTINGS.. Choose Save & Reboot..Also In there If You See.. ENABLE FAST BOOT, or something Similar.. Set it to that to Bypass the screen youre seeing.. Hope that helps your Problem.. Cheers
http://www.wnycomputerpro.com
Jun 03, 2008 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
409 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
