Question about Kenmore 24.7 cu. ft. French-Door Bottom Freezer Refrigerator
LG Refrigerator 78753 LED Assembly
LED Assembly is down to one flickering light. How do I remove and replace the assembly after I purchase a new one.
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
KFFS20EYMS00
KitchenAid Refrigerator Not Defrosting - Model ...
www.repairclinic.com/...-/KitchenAid-Refrigerator-not-defrosting-KFFS...
Show all parts for model KFFS20EYMS00 ... If the defrost heater assembly has burned out, the frost will build up on the coils and eventually no air will be able to ...
Jul 28, 2015 | Freezers
Ice maker fills and freezes won't dump ice. It will if I hit the test button but not on its own
It sounds like it may be a bad freeze sensor. Consider having it services.
HOWEVER
The first thing I would recommend is removing the necessary grills and clean the condenser area and be sure the fan is operating. This becomes a problem in clean homes because the dirt slides on the floor and into the condenser coil where as the dirt sticks to a dirty floor.
Jun 20, 2015 | Samsung RF260BEAEWW 25.5 cu. ft. French...
Need to replace the water inlet solenoid
The Samsung side by sides and french doors have split systems meaning both freezer and ref have evaps. Your water reservoir could be frozen. They have DC heater that is attached to reservoir so it does not freeze, this could be your problem. The other problem that I have run across is the water line in the door can be frozen. If it is the door, you can check by locating where it enters the door, because it will have a quick disconnect. Disconnect water line and grab a cup and place cup under diconnected line coming from cabinet on the door and press or have someone call for water on fountain. Let me know if that helps. Thanks Logan.
Apr 07, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
Feb 26, 2014 | Samsung RS261MDPN Side By Side...
I HAVE A MAYTAG UPRIGHT FREEZER THAT DOES FREEZE . IT RUNS BUT DOES NOT GET COLD
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Jul 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Replacement interior bulb socket
First off its the repair mans problem not an electrican, he probably knows its a hard job and does not want to do it, probably be alot of work to replace it, check with Victory an see it a replacement part is available an ask how hard to replace.
Nov 11, 2008 | Victory Freezers
Kenmore 24.7 cu. ft. French-Door Bottom Freezer Refrigerator Logo
13 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
