Question about KitchenAid Countertop Toaster Oven KCO111
Need a replacement function switch for Kitchen Aid KC0111
The heater is not turning on
Sounds like the thermal fuse has blown. Consult your manual to bring it to a appliance repair shop. Should be an easy fix.
Aug 10, 2016 | KitchenAid Kitchen Aid KCO222OB - 12-in...
Power switch not working
Yes, anything can be fixed. They can be difficult to get apart sometimes, just be gentle and pay attention and you will figure it out.
Apr 14, 2013 | KitchenAid Kitchen Aid KCO111CU - 10-in...
Bake no longer works
Kitchen aid will not help, will not sell the part and will not give you a part number for ordering.
the part that goes bad is one of the 2 piggy back function switches. it gets hot from electricity and deforms the plastic causing the connection inside to fail.
I traced all the wiring and made a schematic to use for testing. Kitchen aid refused to even talk about it, so what I share is from my own experience.
By the way, I could not find this part (fz31-9) other than in china and it has a specialized cam inside and 5 connectors. there are 8 that match and not knowing witch cam, makes it very difficult to guess.
the attach diagram worked for me, but it man made and could contain errors.
Mar 11, 2012 | KitchenAid KCO222OB Toaster Oven
Hi! I need a toaster control knob from the front of my model KC01005 toaster oven. Where can I get one? Thanks, Bill
Try the kitchen aid site, Email them with the model number and let then know what you need and the price of it. Sometimes with the part being small, they will send it free of charge
Apr 04, 2010 | KitchenAid KCO1005OB 1400 Watts Toaster...
On/off timer button broken, just spins, kids may have twisted wrong way
It would help us to answer your free question here if you include a make and model #..
Also - your question looks a bit like a statement.. Please ask your question clearly..
Are you looking for a replacement timer button ?
Thank you..
Sep 23, 2009 | KitchenAid Toaster Ovens
Kitchenaid kco1005 toaster oven broken timer dial/knob
My kitchen aid toaster oven when set on baking the light is not coming on.
Aug 20, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
My KA KCO100508B blew its thermal fuse after 3 years. I found a replacemnt close to 206 centigrade for $2.60 at Appliance Parts Warehouse near my home in Smyrna, GA. Know what to ask for when you enter APW. They don't like selling potential fire hazards to novice repairpersons!
Mar 05, 2009 | Toaster Ovens
KitchenAid Countertop Toaster Oven KCO111 Logo
90 people viewed this question
Top KitchenAid Toaster Ovens Experts
Think Crucial
Think Crucial
Tom Chichester
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
