Question about Watches
Relic watch zr18015
How do i open the caseback?
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
escapement
  • 2334 Answers
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Do not forget to rate, please.
Posted on Jan 26, 2009
SOURCE: how to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
Posted on Mar 13, 2009
disap1
  • 98 Answers
SOURCE: How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Posted on Jan 09, 2010
escapement
  • 2334 Answers
SOURCE: set the date on my new relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Posted on Mar 23, 2010
Swiss army stopped
If qz. see previous answer. If it's mechanical and absolutely all the moisture is not eradicated then rust may begin to form and will over time cause damage. So if it's mechanical take it to a watchmaker for servicing asap.
Please rate my solutions.
Jul 26, 2009 | Relic 0504648FA
Watch stopped running
Examine the caseback of the watch. You will find the lip (small gap between the case and caseback). This is exact point where to insert watch openers blade and pry caseback up.
Rate me, please.
Mar 26, 2009 | Watches
REMOVE BACK COVER
If caseback is without grooves, it is snap on caseback and you have to insert openers blade under the lip and pry up. Lip is the tiny gap between the case and caseback.
If you have groves in caseback, it is screwdown caseback and you will need special opening tool. Insert the blades in to the grooves and unscrew the caseback.
You can find this tool on eBay.
Rate, please.
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
I have a cheap pocket watch that needsa new battery, and i do not know how to open it. does not look like the kind of back that wil pop off,could it be a screw on type?
Pocket watches are 99% with the back snap-on/sanap-off opening. Never came across the screwback. Get the knife with the solid blade, insert the blade in the groove between the case and the caseback and push it in quite hard using lever action (pry up). At the same time make sure the blade do not slip into the movement, as it will damage your watch.
If there is no groove between the case and the caseback, then watch must be opened by removing bezel (metal ring holding glass in place). Open the same way as for the caseback, just be VERY carefull, as any slip of the blade will leave the marks on dial.
Feb 27, 2009 | Relic Degrade Pocket Watch
Taking back off relic watch
Jan 25, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
CH2301 battery replacement. How open compartment?
There are 2 ways that Fossil closes the caseback on their watches.  It is either a 'pop-off' caseback that you will need to pry off.  Get something very small and thin, such as a small flathead screwdriver.  There is usually a small groove somewhere around the edge of the caseback where you can insert the blade.  The other type screws off.  You will need to unscrew the caseback.  You can determine if it screws off by looking for 6 notches around the outside edge of the caseback.  You will use these notches to insert a tool to rotate the caseback off.  Without a specialized tool called a watch-wrench, I suggest bringing it to a store such as Precision Time or Tourneau.
Jan 18, 2009 | Fossil CH2331 Wrist Watch
Trying to replace battery in Kenneth Cole C275-04-KC3522
You need a watchmakers knife or caseback opening tool to open your watch.
1)If your watch has screwdown back, there should be grooves in caseback where you have to put in opener and unscrew that caseback.
2)If your watch has a 'clip-on' caseback, you have to carefuly examine the caseback and find the groove between caseback and watch case (it is called 'the lip'). This is the right point where to insert the blade of wtchmakers knife and open it using pressure and lever action.
3)The safest, but dearest way is to visit your nearest watch repair shop and ask for battery replacement. You may ask the watchmaker to show you how to do that, so, in future you can do that yourself.
Jan 13, 2009 | Kenneth Cole KC1104 Wrist Watch
Replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Dec 15, 2008 | DKNY Women's Crystal Bezel Watch
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Watches Logo
37 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
