Question about Kenmore Washing Machines
My kenmore 70 series washing machine does not drain and now will not spin.
  • Mark Nichols May 11, 2010
    change the lid switch!!! you can either one by pass the switch or cut the wires to the switch and connect them and see if it works but i bet it will!
    If that is not the case then i think that is an older machine correct? you will be spending some money and alot of time changing the pump and belts
    Genius:
  • 1,122 Answers
Bad lid switch,by pass it,remove the 2 plastic end caps on the head if it has them,there is a screw on each side,remove them,flip the head up,unplug the lid switch jack on the washer,,cut the 2 outside wires and wire nut them together,plug back in and your done,let me know how you make out-mike
Posted on May 08, 2009
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore series 70 washer will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Kenmore washer series 70 wouldnot drain water
heatman101
Jul 23, 2011 | Kenmore Washing Machines
My kenmore 70 series washer is draining but clothes are still dripping wet
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 01, 2011 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
Washing Machines Logo
174 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
