Question about Motorola Talkabout T5500 (7 Channels) 2-Way Radio
Disable the beep when pressing the ptt button on motorola t5550
5 Suggested Answers
alexis_garci
  • 4 Answers
SOURCE: Motorola T8500 Communication Problem
Agree with eradiostore, check your batteries and battery contacts. Remenber to turn off the radios before charging.
Posted on Jun 12, 2009
eradiostore
  • 1654 Answers
SOURCE: I have 2 Motorola P110 2 Ch Radios. One powers up
There a a few things which could cause this:
1) You have the radio set to an unprogrammed channel.
2) You have a bad, low or defective battery. (Try switching batteries with the other unit and see if the problem goes away.)
3) Your radio needs repair.
4) Your radio has busy-channel-lock-out activated and you are trying to transmit on a frequency which has activity in your area.
Posted on Oct 01, 2009
eradiostore
  • 1654 Answers
SOURCE: How do you silence beeping
Hold the + (plus) button in while turning the radio on to turn the Roger Beep on or off. Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf The instructions are on pg 25.
Best regards.
Posted on Oct 22, 2010
eradiostore
  • 1654 Answers
SOURCE: Motorola T4500 two way radio. Can't
The T4500 is a stripped down version of the TalkAbout radios, it does not offer an option to turn the Roger Beep on or off. Sorry.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
Best regards.
Posted on Nov 01, 2010
Can I turn off the beep on the cxt195?
You mean the "roger beep"? You can try the steps below from this site>>http://science.opposingviews.com/turn-roger-beep-off-motorola-walkie-talkie-10001.html
Step 1
Turn the Motorola Talkabout two-way radio on by pressing the "Power" button.
Step 2
Hold down the "Menu" button for several seconds until an icon appears on the screen. "On/Off" begins to flash on the screen.
Step 3
Press the "Minus" button to turn the "Roger" beep off. If you want to turn it back on, press the "Plus" button.
Step 4
Tap the "PTT" button to save the change. You may also press "Menu" to save the change and completely exit Menu mode
Hope it helps...
Dec 03, 2014 | Radio Communications
Radio keeps beeping when I turn it on? I confirmed its not because of a low battery but something else.
A few thoughts:
If it is a long continuous beep this can be an indication of having the channel select set to a channel which is not programmed.
If it is a beep that only occurs when you press the PTT button, similar to the low battery beep, it could be a battery, battery contact, or internal battery contact issue. Clean battery contacts between radio and battery, as well as external contacts, with a pencil eraser to assure a good connection.
If it is a beep that occurs periodically when pressing the PTT button, it is possible your radio is programmed with busy-channel-lock-out (talk prohibit tone), which would not allow you to transmit on a frequency which is already in use.
Best regards.
Oct 11, 2013 | Motorola Mag One BPR40 Two Way Radio
I ptt and it immediatley 'roger beeps'
Beeping when you press the PTT button usually indicates a bad or weak battery. Check your batteries and charger. Clean contacts with a pencil eraser.
If you feel this is not the problem, then you have a radio problem. These radios are non-repairable, as parts and schematics were never released for them.
Best regards.
Dec 12, 2012 | Motorola Talkabout® T9500 Two Way Radio
How could i program/change the freq of my motorola gp2000 manually
I don't think that you could program/change the freq of your Motorola GP2000 manually since newer Motorola radios today everything is done by computer and programming sotfware. You need to have software for GP2000, radio interface box ( RIB) and programming cable for GP2000 radio and these devices are not cheap. The best way is to contact a local repair shop to have it done for you or find a two-way radio technician, he could do this if he has all the test equipments required.
Radcom907
Oct 21, 2010 | Motorola GP300 Compatible 2 Way Radio...
How to turn off noise after you push to talk
To
disable the ”Roger” Beep feature, turn your radio off and then back on while pressing and holding Scroll +
button. The ”Roger” Beep icon will not appear on the display.
Here is a link to the user guide.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5xXX_User_Manual_E.pdf
Best regards.
Mar 28, 2010 | Motorola Talkabout T5100 (14 Channels)...
When I press the PTT button it will not beep after i talk
either that or take out the batterys and it will reset ist selft
Aug 08, 2009 | Motorola Walkie Talkie 2-Way Radio
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
Nov 28, 2008 | Motorola T7100 2-Way Radio
2-WAY RADIO TROUBLESHOOTING
In a Motorola T500, pressing the + button while powering on enables/disables the roger beep (release of PTT button).
Good luck and kind regards.
Nov 03, 2007 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola t5100
In most Motorola T5XXX series/models, pressing the + button while powering on enables/disables the roger beep (release of PTT button).
Nov 03, 2007 | Motorola Talkabout T5100 (14 Channels)...
Roger Beep
Hi Helen,
On most Motorola radios, to remove the roger beep, while powered on, you need to press the menu button until the Roger Beep indicator in the display starts to flash. Press on the + or - to change status. Press on the PTT to save and exit.
Hope this be of some help. Pls post back if it worked or should you need additional information.
Oct 25, 2007 | Motorola TalkAbout T6530R (14 Channels)...
Motorola Talkabout T5500 (7 Channels) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
