Question about Singer One Plus Computerized Sewing Machine
How to wind bobbin on one plus machine - Singer One Plus Computerized Sewing Machine
4 Suggested Answers
  • 10865 Answers
SOURCE: bobbin winding
http://www.singerco.com/accessories/manuals.html
go to this site and you can request the owner manual which will shoe u exactly how to proceed
Posted on Feb 27, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 1788 Answers
SOURCE: my singer sewing machine 2010 will not wind the
It sounds like your path for your thread around the guide is not correct, read your maual, page 10 and see that you have to cross over your thread to give the right tension, then slide your bobbin over to touch the lever. Also, remember to hold the tail of the thread for a few rotations before you let go. If, you do not have a manual, go to singerco.com and download one for free.
Posted on Sep 13, 2010
I wound my bobbin on my model 1100, pulled it out, treaded the machine, and cannot stop the bobbin filler from turning. Now the machine does not want to sew. Help.
Sounds like the bobbin winder activator is stuck. As long as the bobbin winder is activated, your machine will not sew since that is a safety function.
You might try flipping the bobbin winder activator back and forth and see if that releases it--or try winding some other bobbins. If it will not release, then you may need to take the machine for service.
If the bobbin winder is worn or defective, you can look at purchasing a stand-alone bobbin winder (called "Sidewinder") available online through Amazon, JoAnn's, etc. for about $30. It saves wear-n-tear on your machine plus allows you to quickly wind multiple bobbins without unthreading the machine. You can get battery operated or one that also has an AC cord.
Sidewinder bobbin Google Search
Oct 02, 2017 | Sewing Machines
Hi, I have a PFAFf tipmatic 1025 sewing machine and the needle does not stop going up and down while I wind a bobbin. I have put the wheel in the position for bobbin winding. What can I do to fix it?
well if it is in the right spot, and nothing else works, just take the thread out of the machine and can remove needle if you are worried about it breaking and then just wind the bobbin, it won't hurt anything. If you give it a little oil before you start you can work the oil in at the same time. hope it helps good luck K
Sep 22, 2017 | PfaFF Sewing Machines
How to spool thread onto the bobbin
That is called winding the bobbin. Depends on the make & model of your machine. Search for:
Make Model wind bobbin
How to Wind Bobbin Sewing Machine
How to Wind Bobbin
Jul 06, 2017 | Sewing Machines
Bobbin winder not winding cotton on spool a part has fallen in side machine how do l take casing off Janome 480 quilter thank you
Am unable to help with your machine but you can purchase a stand-alone bobbin winder called Sidewinder for about $30. Just be sure to verify that your machine bobbins will work on it. The one I have will use either a power cord or batteries. Great little machine because it saves wear-n-tear on the machine plus you can wind bobbins without unthreading the machine.
Customer Reviews Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Portable Bobbin Winder
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jun 05, 2017 | Janome Sewing Machines
My Memorycraft 10000 is having difficulty spinning bobbins. When I load it up to spin, then start the process, the needle goes up and down, and the machine beeps and stops.
Hm, difficult to say. Perhaps the needle stop function for bobbin winding is not functioning properly. Perhaps taking it for service would be a good idea.
The other thing you can do is look for a stand-alone bobbin winder. They cost around $30-35 at the fabric stores (ie JoAnn's) or can be found online. Just verify first that it will take the bobbins for your machine. I have one and it's great because it saves wear n tear on my machine, plus I don't have to unthread my machine to wind the bobbin.
Nov 27, 2016 | Sewing Machines
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
How do I fix the bobbin winder on the 155. It has stopped working completely.
Unable to provide advice without the make & model.
However, in the meantime, you can purchase a stand-alone bobbin winder at the local fabric store or online for ~$30. One brand is called "Sidewinder." Be sure to verify that it will work with your machine's bobbins as some bobbins do not fit!!!
FWIW, it is nice to have a separate bobbin winder so you don't have to stop in the middle of your project, remove the thread, wind a new bobbin, and then rethread the machine.
Sep 30, 2016 | Sewing Machines
Bobbins wind unevenly- tension issues
Sounds like it is actually the tension on the bobbin winder. Make sure that the thread is following the correct path to the bobbin. Other than getting it repaired, a stand-alone bobbin winder (avlb @ JoAnn's or online) for ~$30 would work. One brand is called the Sidewinder. Verify that your bobbins will work on it because some Singer bobbins will not. It's a nice accessory to have because it saves wear 'n tear on your machine plus you can wind bobbins without unthreading the machine.
FWIW, it is usually better to wind bobbins at a slower speed. Higher speed will tend to make the bobbin jump around and the thread to pop off. In addition, higher speed will tend to stretch the thread going onto the bobbin. The thread will not relax until unwound from the bobbin and stitched into your garment. It may cause the fabric to pucker as the thread relaxes. Slower is better!
Apr 15, 2017 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin winder on Brother XL2230 not working properly; hesitation in that area is causing bobbin to wind erratically.
You can take the machine in for service or purchase a Sidewinder Bobbin Winder.
Service begins around $60 plus parts and the Sidewinder is less than $30.
Apr 28, 2010 | Sewing Machines
Singer One Plus Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
