SOURCE: how to connect dv camcorder to pc?
the user manual is here http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?l=en&m=DCR-HC21E online
SOURCE: I have a Sony Handycam DCR-TRV22E Mini DV Digital camera and cannot get my PC to recognise it.
Go to camera menu and enable USB Stream, problem will be solved and PC will recognise your camera.
SOURCE: where to download software for my sony handycam DCR-HC22E Mini DV
you can download the applicable softwares from the following link
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC21
select the operating system from the dropdownlist below and if it is XP you have then select XP instead of XP SP2
cheers
SOURCE: Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
