Question about Abu Garcia Fishing
I HAVE A LEVEL WIND MODEL TGC6000C AND HAD A P ROBLEM WITH THE DRAG NOT LOCKING IN PLACE IT SIMPLY REELS BACKWARDS ANY IDEAS AS TO WHAT I MIGHT NEED TO FIX? LOCK IN REVERSE PART NOT WORKI
csmock132
  • 4669 Answers
SOURCE: wont go into reverse and doesnt go into 3rd unless i let off gas
It sounds like you broke the sun gear shell in the transmission. This is real common on 4L60E. The transmission will have to be disassembled to fix it. If this is what is wrong it will have no reverse and hold 1st till about 30 and then skip 2nd, right to 3rd. Then never shift in to 4th.
Posted on Mar 11, 2009
  • 142 Answers
SOURCE: ratchet/click stops do not work,but spring still reels in,no rust or dents in any part
catch pawl in the reel is shot. I used to work in places where this happened. The only solution is tie the hose off on to a stationary object.
The only other solution is replace the reel..
Posted on Jun 03, 2009
harley9701ha
  • 424 Answers
SOURCE: Hood latch on my 1999 F-150 won't lock and hold
The spring for the latch return could be broken,or the cable may need to be pushed back in at the handle.
Posted on Jun 10, 2009
ted1430
  • 339 Answers
SOURCE: engine appears locked up as it won't wind up to start
Try turning the water almost off at the faucet and then loosening the water feed hose connection where it attaches to the washer. Sometimes the pressure in the pump is so high that it will effectively lock the engine and you need to relieve the pressure to be able to restart it. Once it does restart, get the water flow back ASAP as the water is used for cooling and it needs to be there quickly.
Posted on Aug 16, 2009
SOURCE: Retractable Cord won't lock
When fully extended (you have to hold the cord in place since it won't lock), slide the rectractable device down the cord until it is butted up against the USB connector. You can use the mouse with no problems like this. When you are done, slide the retractor back to the middle of the cord and the ends will wind back in. It's not a perfect solution but at least makes the mouse usable.
Posted on Sep 08, 2009
Where can I get a schematic on K Mart 207 level wind fishing reel?
Some quick research revealed that the original manufacturer of that reel was Olympic Reels based in Japan. Unfortunately I did not have any success in locating a schematic.
Contact Mike Willsey at this link Home after January 9th and he should be able to assist you.
Oct 13, 2014 | Fishing
The level wind guide moves when reeling in but does not move when the line is running out what is wrong
There may not be anything wrong.
some levelwindays reels disengage the line guide during casting or when releasing line.
Sep 23, 2014 | Fishing
How to open up a okuma komodo reel
to open the reel and access the worm gear cog ( the gear that actually drives the level wind ) you will need to remove the handle, the star drag assembly, the side plate screws etc. Before you do all of that look directly at the front of the reel beneath the level wind face plate is the worm gear pawl ( the tooth that actually rides in the level wind gear itself ) there is a cap with a flat head screw driver slot in it, remove the cap ( if you can access it with the face plate on other wise youll have to go thru the steps previously mentioned) and carefully tap the reel until the pawl itself falls out there will also be a very small washer that goes inside the cap. Inspect the pawl for defects like chips on the points that ride in the gear. also inspect the worm gear it self, debris that gets lodged in the gear from regular use can chip the ends off of the pawl which will cause the pawl to stick to one side or in extreme cases stop working all together. It is possible that the worm gear cog ( located in side the reel ) is damaged but almost every reel with this issue that I have repaired (100's of them) is caused by a damaged pawl or worm gear it self Dark Side Reelz
Aug 17, 2014 | Okuma Komodo Low Profile Baitcast Reel
How do you change the retrieve to left or right hand on a orvis encounter fly reel ?
Drag factory installed for left-hand wind. To change your real to right-hand wind, remove spool, pull the keyed bush and clicker plate assembly off the spindle. Flip the clutch bearing (silver) and reassemble.
May 21, 2014 | Orvis Encounter Large Arbor Fly Reels &...
Snarled line on low profile reel.
readjust your drag and use your thumb more when casting . free spool reels still need casters help
Apr 25, 2010 | Shimano REELS TYR20 Tyrnos Lever Drag...
How do you use the shimano tiagra level drag reels for trolling
i have a mony of 2,5000 may sister want by a bag to her self? how mach laef may money whe i by a bag wen a bag is 1,5000?
Apr 03, 2010 | Shimano REELS TYR20 Tyrnos Lever Drag...
Missing Tesion Knob for mechanical Drag. I need to
google brand name for phone number of company and call them sometimes they will send u parts like that for free or try e bay
Jun 19, 2009 | Pinnacle Inertia Baitcast Reel
Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Apr 15, 2009 | Penn Gt Series Levelwind Reels 330GTi
Fishing Logo
Top Abu Garcia Fishing Experts
Ngoro
Ngoro
ray gallant
Steve P
Steve P
Are you an Abu Garcia Fishing Expert? Answer questions, earn points and help others
