Question about Garden
The mower will not stay running when I ingage the blades an I have to jump start it an put gas in the carb to get it to start but when it starts it stays running till I pull the botten to start the bl
Hi when I pull the botten to start the blades the mower stops running an to get it started i have to put gas in the carb an i am getting full all the way to the carb an i have to jump start the mower everytime could this be the batt doing all this ?
  • 246 Answers
Hello itsmcfly32:
From your Description it Sounds like a Stator/Charging Coil Problem.
If there is Not Enough Voltage to Keep the Carburetor Solenoid Open with the PTO Engaged, then the Stator/Charging Coils or the Voltage Regulator (if Applicable) is is Bad and this is causing Low Voltage that is Causing the Carburetor Solenoid to Shut Off the Gas Flow to the Carburetor Jet when you Engage the Blades; or the Seat Safety Switch is Bad and Requires Replacing or the Conection Points Require Cleaning.
Check the Seat Safety Switch First.
>>The Following is the Instruction File for Checking the Seat Safety Switch.
>>***PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.***
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed. **Make Sure the Switch has a Good Connection. Now; On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch Jumper from Same Color Wire to Same Color Wire). The Seat Safety is Showing No One is Seated in the Seat when the Clutch or Blades are Engaged.**
If the Seat Safety is Good, then
Check the Voltage.
>>Go to this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=bkP1h4rj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjksMjkmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1DaGVja2luZyB0aGUgQ2hhcmdpbmcgU3lzdGVt&p_li=&p_topview=1 and Use the Information and the Test Chart Links to Properly Determine the Charging System on your Engine and Correctly Test the Charging Sytem to Determine if it is Charging Correctly. These Charts and the Testing can be Used for Almost All Small Engine Charging Systems (Kohler, Tecumseh, Honda, ect). This Site Addy; http://www4.briggsandstratton.com/miscpdfs/RNT/alternator_id.pdf will Assist you in Determining you Charging System on this Engine.
The Following is the Instruction File I Made for Removing the Flywheel from Most Mower Engines. It is the Basics and if you have a Question, Please Ask. Any Input to Make this File Better is Appreciated. ***Disconnect the Coil Wire from the Spark Plug. Remove the Blower Housing (metal engine cover). Remove the Coil. Remove the Flywheel Nut or Starter Cup (Depends on the Model). Now Attach a Steering Wheel Puller to the Flywheel Using the Threaded Holes in the Flywheel. Tighten the Puller. Now Hit the Puller with a Hammer. Repeat this Procedure Until the Flywheel Pops Up or can be Lifted Off the Crankshaft. On Some Models you Can Not Use a Puller and Must Use a Pry Bar and a Pipe Cap that is Slightly Larger than the Crankshaft. Place the Pipe Cap Over the Crankshaft to Protect it. Place the Pry Bar Under the Thick Section of the Flywheel and Pull Up Against the Flywheel. **BE CAREFUL DO NOT PUT A HOLE IN THE BLOCK UNDER THE FLYWHEEL** Now Hit the Pipe Cap that is on the Crankshaft (covered with the Pipe Cap). Repeat the Procedure Until the Flywheel can be Lifted Off the Crankshaft. *** Be Sure you have the Flywheel Torqued to the Proper Torque (I require the Model and Spec/Type Numbers Off the Engine to Provide the Proper Torque) and Set the Coil Gap to .020in.. The Stator (Charging Coil) is the Flywheel. Simply Disconnect the Wires, Unbolt the Stator and Replace with a New Stator. Assemble the Engine and you are Good to go.
Replace the Voltage Regulator if you Determine it is Bad.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Mower doesnt seem to get gas
Sounds like a dry or stiff diaphragm. Any motor will start provided three things take place. Spark at the right time, compression and gasoline. Try this trick. Remove the air filter from the motor. Put on the choke. Being careful to stay away from the turning blades put your hand over the carb and see if it starts when you pull the cord. Did you see gasoline in the carb? If not then the tube carrying the gas up to the carb is probably disconnected. If it does start then try again to start it in the normal manner. If it does not start normally then you will need to replace the diaphragm. Make sure you have spark see if the motor seems to have poor compression. Poor compression will also cause the gas from not getting up to the carb. If it is new as you say take it back to the store
Jul 01, 2014 | Briggs & Stratton Garden
When trying to start my husquavarna 4824 zero turn mower it does nothing starter does not engage and battery is ok
Check your blade ingage switch. Sometimes they stick. You can jump start it by jumping across the solenoid switch beside the engine. I sometimes have to engage and disengage my blade switch and it starts. Hope this helps.
Sep 30, 2013 | Husqvarna Garden
Will not start
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Feb 18, 2012 | Cub Cadet Garden
Small engine won't start
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.~~
Feb 09, 2012 | Garden
Cant get 5.5 hp Briggs and stratton to start after cleaning out fuel lines tank and carburator changed plug it ran for a sec then died again what now
Jan 22, 2012 | Mtd Garden
I have a yard machines 46 inch cut 18.5 hp riding mower that wont start. i changed ignition swith and soleniod. if i cross wires on solenoid it will start after putting gas in carb. it runs till gas runs...
I would start with the safty switches. Look for them on the deck engager, seat??, break/clutch pedel,blade engager lever. Remember the blade sw. must be disengaged be fore it will start. Ifit runs as you said It is in the wiring/ electrical system. I know it is not in the ignition sw. or seloniod. szm230
Apr 15, 2011 | Yard Machines Garden
Checking the carberator
to see if its carburator spray some starting fluid in the throat it will start then die its not getting gas through thr volosity tubr take the bowl holder which is a hollow bolt try to keep the bowl on or the needle will come out clean the small holes to the sides and the top with a tip cleaner that they use for welding tips in the hollow bolt put back on should take care of problem unless its all gummed up in thr carburator
Aug 09, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Jun 09, 2009 | Garden
Won't stay running
The carbeurator needs to be cleaned and probably rebuilt. Start with a spray carb cleaner by putting 3 or 4 shots in the carb. Run it for a minute then let it sit for two hours and run it again.
May 07, 2009 | Garden
Garden Logo
335 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
