Question about Makita 763198-1 3/8" Keyless Chuck Conversion Kit for Cordless Impact Drivers with 1/4" Hex Drive
How to use makita keyless chuck and tighten/loosen frill bit
rowdy45176
  • 2176 Answers
SOURCE: chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Posted on Jan 08, 2009
  • 100 Answers
SOURCE: Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
  • 16 Answers
SOURCE: HOW DO I LOOSEN A KEYLESS CHUCK TO REMOVE A DRILL
Keyless chucks normally have a knurled ring at the base of the chuck that you hold in one hand while turning the large knurled taper with the other. If the chuck has been overtightened, and you cant open like this, try using two stilson wrenches (Pipe wrenches) one on each of these parts. Use a soft cloth in the jaws to avoid damaging the knurling. You can also try some Q20 or similar into the chuck to help lubricate it.
Posted on Jun 15, 2009
  • 44 Answers
SOURCE: remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Posted on Oct 23, 2009
How do I load the drill bits in the keyles chuck of my Metabo impact drill Model SBE 561?
Keyless chucks work one of two ways
1: Simply turn the chuck by hand to loosen or tighten drill bit, once it grips the drill bit you will not be able to turn it anymore
2: Some keyless chucks operate by pulling the chuck back towards the body of the drill, placing the drill bit in and then releasing the chuck back to its original position
Sep 08, 2014 | Drills
I'm looking for keyless chuck to makita btd 140
The Makita BTD140 is an impact driver that has a hex-drive anvil and bit holder assembly, it does not have a keyless chuck accessory. There are some aftermarket chucks with hex shanks on them to put into impact drivers but I've seen very few that hold up.
May 29, 2014 | Makita Drills
How do I remove the drill bit from a Makita6223D?
If your drill has the original keyless chuck on it, there are two plastic rings on the chuck. The outer ring should tighten and loosen by hand enough to hold the bit(s). The inner ring is to hold on to if the chuck gets overtightened. Chucks do wear and get corroded over time and can get locked in position. If you can't get it loose by hand, channel lock pliers can help. If the chuck is that bad you may need to replace it.
Mar 03, 2013 | Makita 9.6v Cordless Impact Driver 6903VD
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
Sep 26, 2012 | Makita BDF452HW Factory Reconditioned 18V...
How to fix the bit
If your Makita matches the one on the picture, you will need a chuck key to attach a drill bit or tool to the machine's chuck. The chuck key inserts to any of the small holes in the front part of the chuck and at the same time its teeth interlocks with the teeth of the chuck. When turning the chuck key you will widen or loosen the grip of the three jaw pieces, that clamps to your tool or bit. Tighten the chuck key by hand until the chuck grips the bit securely. For safety, unplug the power cord whenever operating the chuck key on the chuck.
Jan 09, 2011 | Makita & 1/2 Inch Drill
I have a craftsman electric drill model no. 315.10419, i would like to know how to loosen/tighten the chuck for the bits. it is not the regular notched tightener but has a pull down shaft similar to an...
I have the same drill and love it !! This series of Craftsman Drills are the first of the keyless chuck. To tighten or loosen the bit, simply pull back on the black ring tightly and hold it and simultaneously pull trigger to run drill foreward (to tighten bit). Reverse (to loosen bit). The chuck will make a loud clicking sound!! This is normal !
Jun 23, 2010 | Craftsman Drills
How to tighten drill bit on makita 6343d
your must have a keyless chuck. hold the black center part of the chuck and run the drill forward or backward to open or close the chuck.
Jan 26, 2010 | Drills
May 04, 2009 | Makita Drills
Makita 763198-1 3/8" Keyless Chuck Conversion Kit for Cordless Impact Drivers with 1/4" Hex Drive Logo
29 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
