Question about Hotpoint Ovens
Hotpoint oven display C001 - Hotpoint Ovens
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Hotpoint oven suddenly stopped working
Sounds like a control board problem. When the display goes out that is usually a dead board.
Mar 10, 2014 | Hotpoint Ovens
Hotpoint sy36x display works but fan and element not working, connections seem ok
You need to ascertain that the components are getting a supply to them.
You will have to remove the oven from the housing, and remove the rear cover to check for supply to fan and element.
Jan 05, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint SY36 oven cuts out but fan keeps running
do you get code in display if so what is it . oven cutting out is a high temp problem probably / look for a thermo problem or sensor if digital . need a complete model # to help more if needed . hope this helped mm
Dec 04, 2009 | Hotpoint SY36 Style Line Stainless Steel...
F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Jan 25, 2009 | GE JKP15 Electric Single Oven
Hotpoint BU62 display works but nothing else does.
If the display is flashing auto, then you need to reset it to manual, otherwise oven will not work,
The grill should still work regardless..If you have your handbook, refer to (What if something goes wrong).
If no hand book, type in HOTPOINT USER MANUALS in your browser bar, and follow the links.
Please leave feedback
Dec 02, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Display works but no lights on either oven and no fan
If the display is flashing, it sounds like the timer needs resetting
U need to refer to your instuctions on how to do this..
If it does it again once u have reset it, then I suspect that the oven element has blown..
Pls leave feedback.
Thanks.
Nov 28, 2008 | Hotpoint DY46 Style Line Stainless Steel...
I can't find the model no. on my Hotpoint Ovan!
FFF Control Error, Failed EEPROM Replace Control
You can try a hard reset . turn off the power for 1 minute.. also you can check the connections to the control .. other then that you will have to repalce the control
Sep 29, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Hot point beeper wont stop
This is a code for an over temp condition.
If the oven is cool then there is a problem in the sensor circuit, usually a failed temp sensor.
Post back if you have any questions.
Nov 18, 2007 | Hotpoint SY21 Style Line Gas Single Oven
Function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Ovens Logo
97 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
