Question about Horizon Rst 5.6 Treadmill Walking Belt
RST 5.6 Trouble code 101 1-06 - Horizon Rst 5.6 Treadmill Walking Belt
How to reset a service interval indicator on a 2003 mini one
Resetting Oil Service Light on your 2002 - 2006 Cooper and Cooper S Hatchbacks, and 2005 - 2008 Cooper and Cooper S Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word "RST" to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the "RST" message to fl ash.
8. Release, and then press & release (once only).
Jul 01, 2014 | 2004 Mini One
NEED AQUALITE MANUAL - CAN'T SET TIME
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press any button on the watch.
Apr 09, 2010 | Watches
NEED THE INSTRUCTIONS FOR AN AQUALITE 100 jstreiter@comcast.net
To set time:
To set Alarm time:
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Mar 26, 2010 | Bulova Watch
How do you set the time?
To set time:
To set Alarm time:
Jan 13, 2010 | Watches
Saving the info that i entered in my visual basic in microsoft access.. how to code the save???
check this out
Rst.Open "users", strConnect, , , adCmdTable With Rst .AddNew .Fields("username") = txtname.Text .Fields("User_Password") = txtpws.Text .Fields("Access_Type") = cmbUserTypes.Text .Fields("Date_Created") = Now .Update End With Rst.Close
'#### connection to databas
Public connConnection As New ADODB.Connection Public rsRecordSet As New ADODB.Recordset Public rsRecordSet1 As New ADODB.Recordset Public Rst As New ADODB.Recordset Public Rst1 As New ADODB.Recordset Public Rst2 As New ADODB.Recordset Public Rst3 As New ADODB.Recordset Public strConnect As String Public ConnectionOk As Boolean
Public Sub ConnectionMOd() Dim strProvider As String Dim strDataSource As String Dim strDataBaseName As String Dim i As Integer On Error GoTo ErrorTimer strProvider = "provider=Microsoft.Jet.OLEDB.4.0;" strDataSource = App.path ' strDataBaseName = "Z:\database.mdb" ' strDataSource = App.Path strDataBaseName = "\database.mdb" strDataSource = "Data Source= " & strDataSource & strDataBaseName strConnect = strProvider & strDataSource
Set connConnection = New ADODB.Connection connConnection.CursorLocation = adUseClient connConnection.Open strConnect
Set Rst = New ADODB.Recordset Rst.CursorType = adOpenStatic Rst.CursorLocation = adUseClient Rst.LockType = adLockOptimistic ' adLockOptimistic
Set Rst1 = New ADODB.Recordset Rst1.CursorType = adOpenStatic Rst1.CursorLocation = adUseClient Rst1.LockType = adLockOptimistic
Set Rst2 = New ADODB.Recordset Rst2.CursorType = adOpenStatic Rst2.CursorLocation = adUseClient Rst2.LockType = adLockOptimistic Set Rst3 = New ADODB.Recordset Rst3.CursorType = adOpenStatic Rst3.CursorLocation = adUseClient Rst3.LockType = adLockOptimistic ConnectionOk = True Exit Sub ErrorTimer: MsgBox "Error Connecting To DataBase Please Check Network path", vbCritical, "Connection Error" End End Sub
Jan 08, 2010 | Microsoft Visual Basic Enterprise Edition...
How do i reset my kilometer gauge after changing oil or does it reset to 0 automaticly
Resetting Oil Service Light on your 2002 - 2006 MINI Cooper and Cooper S, and 2007 - 2008 MINI Convertibles:
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
5. Watch for the word “RST” to appear on the Odometer indicator.
7. Wait for the “RST” message to fl ash.
Apr 12, 2009 | 2003 Mini Cooper
How to connect from jsp login page to database
hey try this code......just found it on the net... Put the code in tomcat and test the application through browser. The browser should display the display the data stored in the table.
Here is the code of our JSP file
<%@ page language="java" import="java.sql.*"%>
<html>
<head><title>Read from mySQL Database</title>
</head>
<body>
<p align="center"><b>Following records are selected from the 'jakartaproject' table.</b><br>&nbsp;</p>
<div align="center" width="85%">
<center>
<table border="1" borderColor="#ffe9bf" cellPadding="0" cellSpacing="0" width="658" height="63">
<tbody>
<td bgColor="#008080" width="47" align="center" height="19"><font color="#ffffff"><b>Sr.
No.</b></font></td>
<td bgColor="#008080" width="107" height="19"><font color="#ffffff"><b>Project</b></font></td>
<td bgColor="#008080" width="224" height="19"><font color="#ffffff"><b>Url
Address</b></font></td>
<td bgColor="#008080" width="270" height="19"><font color="#ffffff"><b>Description
of the project</b></font></td>
String DRIVER = "org.gjt.mm.mysql.Driver";
Class.forName(DRIVER).newInstance();
Connection con=null;
ResultSet rst=null;
Statement stmt=null;
try{
String url="jdbc:mysql://192.168.10.2/tutorial?user=tutorial&password=tutorial";
int i=1;
con=DriverManager.getConnection(url);
stmt=con.createStatement();
rst=stmt.executeQuery("select * from jakartaproject ");
while(rst.next()){
if (i==(i/2)*2){
<tr>
<td bgColor="#ffff98" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffff98" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffff98" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffff98" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
}else{
<tr>
<td bgColor="#ffcc68" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffcc68" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffcc68" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffcc68" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
i++;
rst.close();
stmt.close();
con.close();
}catch(Exception e){
System.out.println(e.getMessage());
</tbody>
</table>
</center>
</div>
</body>
</html>
Feb 27, 2009 | Compaq Computers & Internet
Mini dash
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
backbutton0001.gif Article Date: Jan 02, 2007
Car Accociations: NEW_MINI
Hits: 16731
Jan 13, 2009 | 2002 Mini Cooper
Am not able to add/ retrive data
Proper syntax is:
With rstTemp
.AddNew
!FirstName = strFirst
!LastName = strLast
.Update
End With
Do you have the ADODB library loaded?
While in "Code" view...menu/tools/references ... look for a check by "Microsoft ActiveX Data Objects x.xx..."
If you don't have ADO reference library then setting ADODB recordset won't work no matter what syntax you use.
Hint: try using Ctrl+J while you code. The library will show you available syntax as you type.
Jul 20, 2008 | Microsoft Windows XP Professional
Ms Access - OpenRecordset question
I think you just need to change it to read: Col_Title(iCount) = rst![F + iCount] from the original Col_Title(1) = rst![F + iCount]
Sep 19, 2007 | Microsoft Office Standard for PC
Horizon Rst 5.6 Treadmill Walking Belt Logo
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
