Question about Ricoh Office Equipment & Supplies
Ricoh aficio ld118 sc 500
How to get over this error sc 500?
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
  • 990 Answers
SOURCE: Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Posted on Jan 09, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
What is SC500 error on Ricoh Aficio 2020D?
gear assy not turning can be many things. Main motor/devlp unit /fuser/ transfer roller
Aug 14, 2014 | Ricoh Aficio 2020 All-In-One Laser Printer
How to clear error code sc 541 on ricoh aficio 2015
i want to make my nashuatec mp 500 copier to be dip in printig
Oct 04, 2012 | Ricoh Aficio 2015 Copier
SC 500 error code on a Ricoh MP161
main motor can turn that is why getting code. can be from photo conductor, to fuser or gear broke in back of copier. Will need tech for this one.
Feb 20, 2012 | Ricoh Aficio MP 2000 Black and White...
Error 500 ricoh 2018
sc 500 is the main motor error. replace the main motor at the back. it will solve the problem
Jan 04, 2011 | Ricoh Aficio 2018D All-In-One Laser...
ERROR SC 500
sc 500 is the main motor error. replace the main motor at the back. it will solve the problem.
Sep 21, 2010 | Ricoh Aficio 2015 Copier
I have a problem RICOH Aficio 2018D A MULTIFUNCTIONAL DISPLAY ON ERROR I prevent my SC 500. How can I solve this problem?
SC 500 : Main motor lock
Symptom:
A main motor lock signal is not
detected for more than 7 consecutive
checks (700 ms) after the main motor
starts to rotate, or the lock signal is not
checks during rotation after the last
signal
Possible Cause:
• Too much load on the drive
mechanism
• Main motor defective
Sep 14, 2010 | Ricoh Aficio 2015 Copier
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Too much load on the drive mechanism
Motor driver damaged
Oct 19, 2008 | Ricoh Aficio 2015 Copier
Oct 18, 2008 | Ricoh Aficio 2015 Copier
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
