Question about Samsung LN40A650A LCD TV
I have a Samsung LN40A650A1FXZA purchased in January of '08. Recently upon power up the TV would display a snowy picture with part of it green in color. It would do this for 4 or 5 seconds then restart on its own. At first it would do this a few times then all was well. Now it continually does it and the only thing I can do is pull the plug. I have researched this model to try some things on my own since it is several months past warranty. I cleaned out the 5+years of dust and thoroughly cleaned the ribbon cable connectors going to and from the TC board. This was successful for about 5 hours of use then the vicious cycle started again. Now nothing I do helps. Where do I go from here? Thank you!
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
  • 4090 Answers
SOURCE: Samsung ln t4665f : Power Light On , No Picture : Clicking Sound
there is a soloenoid type switch that fires the TV up this has failoed. its like a neon or fluoresecent tube that has a faulty starter switch light tries and tries but never quite makes it when it does get going it has that purple smear in the tube. that is the simple explanation for your problem. part is about $60 labor is unkinown as i am not in USA but looking at some of the rip off charges I am glad i dont have the bill
Posted on Aug 20, 2009
SOURCE: Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Posted on Sep 23, 2009
  • 927 Answers
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Posted on Jan 02, 2010
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Replaced the power supply board on my plasma tv. Now have a snowy picture on all inputs. Green light on the logic board blinks evenly. No puffy caps. Is there another board that needs to be replaced?
After the power supply board replacement, Va & Vs voltage adjustment is a must and necessary for the proper working of the plasma display panel. Do it. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 20, 2016 | Samsung 43 PN43D450A2D Plasma TV
My samsung plasma tv powers on has sound and a picture, but is snowy, and coloring is slightly off. I have opened the tv to check for bulging caps and have found no obvious culprits. what next?
Snowy pics are not the symptom of bulging caps.
you must mention what type of source produces 'snowy' pics.
have you tried with other sources and ports ?
I recommend, you test out the following.
- DVD with Component connection
- HDR or STB with HDMI
- TV/Antenna
Aug 15, 2016 | Samsung Televison & Video
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Oct 16, 2017 | Zenith P42W46X 42 in. Plasma EDTV
Samsung HLR5067W goes from a normal picture to snowy green color
Greetings!
I hate to be the bearer of bad news, but it is not something that has a quick fix. Without inspecting it myself it is impossible to say, but the last three of these that I have seen have been bad digital boards and can be a real bear to change, even when you have experience.
I would get slightly different video symptoms when I would switch between the coaxial input to the component input to the HDMI input. But in all cases my on screen display and menu were anomally free. Hope this was helpful, even though I don't think it is something you should attack yourself.
Rob
Jan 14, 2009 | Samsung DLP HL-P5663W 56" TV
Plasma tv has a green snowy patch and a line in the centre of screen
I hate to say it but it sounds like two different problems. Green snowy patch is what they call a diffusion problem and can usually be cleared up by adjusting the VA and VS controls on the power supply board. The other issue is either a drive board, a ribbon connector to the display panel, or a bad display panel(screen). It didn't say what brand you have but these problems are common in samsung, lg, vizio, and several other brands. Good luck and if there is anything else you need just ask and we'll try to fixya, Russmann.
Jul 18, 2008 | Televison & Video
Akai PDP4294 - Snowy, pink & green picture
It is most likely a problem with the tuner, I would contact the place you purchased it or your nearest repair shop.
Feb 07, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Samsung LN40A650A LCD TV Logo
49 people viewed this question
Jerry Greenberg
Jerry Greenberg
