Question about Cuisinart CMW-100 Microwave Oven
Microwave is stuck in defrost and won't release.
My wilkos own colourplay microwave is stuck on defrost how do i take it off defrost ... can someone help?
If it is stuck on defrost, you may have to replace the panel, the control board, or both.
Jul 14, 2016 | Microwave Ovens
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Emerson microwave manual
Emerson Microwave Model # MW899 5W, Open door while running, It keeps running, and the plate stopped not rotating. are there any recalls on this microwave?
Jan 06, 2014 | Microwave Ovens
Defrost lightwont go off so i can start microwave
The relay could be stuck but it makes more sense that the magnetron blew. It could also be a thermal cutoff or burned wire or burned circuit trace on the circuit board
Nov 28, 2013 | Microwave Ovens
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
My emerson microwave turns on but it won't cook or
Check to see if it has a DEFROST SETTING if Defrost setting is on it will not reach an adequate temperature
Jun 07, 2012 | Emerson Microwave Ovens
Sharp microwave door won't open
Usually a mechanical issue with the door release assembly. Likely needs to come apart and parts be replaced. More often, it's cheaper to just replace the microwave as a whole
Oct 10, 2011 | Sharp Microwave Ovens
Microwave is not heating, it seems as if is stuck in defrost mode. Two red lights are showing at the top of the microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 '';
May 28, 2011 | Emerson MW8991SB Microwave Oven
Can't release child-lock on auto-defrost, or auto-defrost is broken.
Probably the only way to get it is to order a copy of the manual from Tritronics.
Either part number MW-9999-19 or MW-9999-21 will work for your model.
But it may not be worth it, since it will run $12.95 plus shipping.
Sep 19, 2008 | Welbilt MR670T Microwave Oven
Cuisinart CMW-100 Microwave Oven Logo
20 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
ray gallant
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
