Question about Ovens
Wiring Oven Diagram
HI ... NEED WIRING DIAGRAM FOR PN 46 ROBERTSHAW OVEN THERMOSTAT
  • 1462 Answers
SOURCE: delonghi esf461st oven not heating up
grill element is separate from oven element. i assume this is a fan oven. take rear panel off inside the oven and the oven element is exposed and you can often see the damage. toncheck properly, take the rear cover off outside the oven and terminals of the element are in view. check for continuity with a multimeter
Posted on Sep 06, 2008
SOURCE: Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Posted on Oct 25, 2008
Powerman
  • 68 Answers
SOURCE: Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Posted on Oct 31, 2008
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
danforddan1
  • 192 Answers
SOURCE: wiring diagram blodgett sho-e convection oven
I dont know much about Blodgett ovens other than how to bake in one and that are top of the line. I use to live next to the factory where they are made. On beautyful Lake Champlane Vt. Go here http://www.blodgett.com/convection_full.htm
you can contact them by phone.
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-018
how about that. please rate me Thanks
Posted on Apr 22, 2009
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
Vulcan Comenda VC200 Wiring Diagram Series: 200/31/0166
Hi i have a belling DF951 fan oven .the heater element stays on when the oven is switch off .Is it the thermostat that is faulty because i can not leave it on .I HAVE TO SWITCH THE MAIN SUPPLY OFF.Or the oven stays on all night
Aug 23, 2013 | Belling XOU174 Electric Single Oven
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
I need a wiring diagram for the replacement ERCU on the JKP27WW1WW oven. Our oven is from 1994 and the new 'clock' module (ERC3) is slightly different where it connects to the 'bake' and 'broil' contacts....
I am not sure if this will help you but I did find a fellow that says he has the adaptable diagram for an updated part on this forum :
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/15496-wiring-diagram-oven-control.html
Oct 30, 2009 | GE JKP27 Electric Double Oven
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
Regards,
Powerman
Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
