RCA L26WD21 Blank screen for 45 minutes, then ok
TV has a basically white screen with blue horiz lines thru screen. At first screen is mostly white, then lines become more evident and the longer its on the more blue the screen becomes. Finally, after about 45 minutes the TV picture comes on and then is ok as long as tv is left on.
Please help - I can find no info on this TV
Elston Miller
elston1942@gmail.com
The answer is very simple as long as your tv is under warranty and not abused. The manufacture RCA do not have the parts to your unit so therefore what they do is exchange your unit. To get your unit exchanged call them and have your serial number ready along with the model that you just posted and they will give you a return authorization number which will allow you to return it. The phone number is a 1-800 number and some of the owners manuel has a 1-877 number anyway to find the number just in case you do not have it go to www.rca.com website and put in your model number look for the owners manuel scroll down to where you see the limited warranty section and you will see that phone number. If you unit is no longer under warranty that is where you will run into a bigger problem since the parts is unavailable.
Posted on May 08, 2009
My RCA console tv has white horizontal lines accross screen, picture is very light and sound is ok, very frustrating. I know its an old tv, but appreciate any response. Thanks
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Jan 26, 2010 | RCA G35773SK 35" TV
RCA L26WD21 No picture/white screen but still have sound
It sounds like the LCD controller board went out, look inside to see if the cable may have come off the LCD controller board. You can look and see what it looks like here: http://www.shopjimmy.com/catalogsearch/result/?q=RCA+L26WD21+
Please post back what you find.
Dec 25, 2009 | RCA L26W11 26 in. HD-Ready LCD Television
There's a very narrow line (white) appears at the very top of the screen when the picture scene is mostly black. A verticle adjustment should fix it but where is it?? RCA F36TF720
it may be an electrolytic cap problem as most newer sets are controlled by an I.C. chip for horiz and vert timing/size/linerity
Nov 02, 2009 | RCA F36TF720 36" TV
Picture goes into horizontal lines while watching then you shut it off for 10 min. or so and it resets it self
solder connections in horiz.drive/output circuit.also solder the flyback transformer.if only 10 minutes you need to solder in the
horiz.circuit area.get a magnify glass and usually will see hair line cracks around the
components.
Jul 17, 2009 | RCA TruFlat 27F520T 27" TV
I have an old sanyo vwm 710 vcr. I have a new hdtv. I can play tapes on the tv if I change the input on the tv. I have selected line 1 on the vcr, but cannot get any channels to come on to record. The...
Not really a solution....RCA customer services (from India, I think), says that there is no way with that VCR because both the front and back (red, yellow,white) ports are input, and the only other jack on the tv is the one for the antenna. Since the digital converter is inside the tv, a splitter would do no good.
I would still have to get either a new VCR with the digital converter in it or get another converter box. An atmosphere of bait and switch is covering this hdtv scheme....
Feb 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
LCD TV White Screen
do you still have this tv? what happens if you hit the info button - does it bring up the banner at the bottom of the screen?
Dec 30, 2007 | Televison & Video
RCA F27442: no picture.
you may have bad solder connection in the horiz.countdown section.
you may also have a GEM Star module bad.
Nov 06, 2007 | RCA F27442 27" TV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
602 people viewed this question
Top Televison & Video Experts
