Question about Hoover HDV7FM Electric Dryer
How to replace dryer
Hi, I have lost manual and need to replace belt on dryer. Can you help?
  • magicrod Nov 19, 2007
    hi , i have to replace the belt on my Hoover TV30 tumble dryer . The original belt has completly feel apart . What i require is the layout of the belt in relation to the motor and the jockey wheel
  • Anonymous Feb 10, 2008
    I NEED TO CHANGE THE BELT IN MY DRYER
  • 46 Answers
Very difficult job. will seem like the new belt is to small. u will need plenty of patience and band aids. take the front off the machine leavin the drum supported only by the rere bearing. slide belt around drum and onto motor pulley keeping the spring loaded pulley on the inside of the belt. (ex hoover engineer)
Posted on Feb 08, 2008
I HAVE A TUMBLE DRYER BECKO DRVS62W THE BELT HAS SNAPPED HOW DO I REPLACE IT. THE DRUM DOES NOT ROTATE MANUALLY IS THIS ANOTHER PROBLEM OR WILL THE DRUM ROTATE ONCE THE BELT HAS BEEN REPLACED.
If this is an electric tumble dryer,
the way to replace the belt is from the rear of the machine,
remove all the screws on the rear silver panel, which gives you access to the internals of the dryer.
And yes the drum wont turn properly if the belt is broken.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Dryers
Was replaceing belt on dryer apparantely the pully broke what the belt wraps around lost the piece dont know what the part looks like or where to get it
Hi crabbypatty7...
The piece you need to find is called an idler arm brackett, it comes with the pulley attached.
You can find your part at: http://www.partselect.com/
Please take time to rate me
Jul 09, 2011 | Dryers
The dryer squeals when it has a load in I am thinking its the belt or bearings but lost the manual so do not even know how to get into it
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 21, 2011 | Dryers
The belt is broken and we need a replacement for it.
Hi and welcome to FixYa, I am Kelly
Go to any of these sites and enter your model number:
http://www.searspartsdirect.com
http://www.appliancepartspros.com
http://www.repairclinic.com
If you have difficulty locating your belt I need your complete model number and will use those same sites to find your belt for you. There are 2 different sized belts for a whirlpool dryer depending upon the model number. 27 inch dryer and 29 inch dryer.
Download this manual to help you change the belt:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The order of removal is the toe panel, top and then the front panel to gain access to change the belt.
Toe panel (page 15 / pdf file page 20)
Top panel (page 14 / pdf flie page 19)
Front panel (page 19 / pdf file page 24)
Make sure you inspect the drum seals (felts) and the the drum rollers in the process of changing the belt.
The manual link I passed is for the 27 inch dryer but access is exactly the same for the larger dryer.
Thanks for choosing FixYa,
Kelly
Mar 30, 2011 | Whirlpool Dryers
I need to know how to fix the dryer belt on model 110.97574100 (gas dryer).Also is there anyway you can email an owners manual for this. I bought it new but lost the manual
Kenmore Gas Dryer
Model #11097574100
Owners Manual does not have drum belt replacement instructions, but service manual does. -- SWT
Aug 05, 2010 | Kenmore Dryers
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
Dryer turn on but would not spin
When the dryer will not spin the most common cause is a broken dryer belt.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 14, 2009 | Kenmore 63942 Dryer
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
REPLACING THE BELT
Hi thanks for the question. to replace the belt. open the door. screws on the inside, under top. remove screws . lift the top. 2 screws on the inside, of front panel. remove. pull front off. now replace the belt. thanks the appliance doc. please rate me. thanks
Oct 05, 2008 | GE DCSR483EA Electric Dryer
Hoover HDV7FM Electric Dryer Logo
425 people viewed this question
Top Hoover Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Archie Ferrarini
Archie Ferrarini
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
