Question about Kenmore 24032\24036 Top Load Washer
Kenmore elite washing machine, Just stopped, small load didn't make it to rinse cycle. Lid switch clicks when I open and close, but cannot restart. How do I take top off and do youthink it is a problem with the lid switch
    Scholar:
  • 86 Answers
The lid switch is a possible problem.Annother possibility is if the machine was shaking for some reason the power cord might have gotten unplugged from the outlet.
Posted on May 07, 2009
Model 9156200 top loading washing machine
the lid switch may be loose or broken it happens to me it was washing but never rinse i found out that it was a loose switch this switch prevents the rinse cycle from working with the lid open because of the high speed rinse ,some machines dont work at all, a loose switch makes the machine think the lid is open even if it is closed.good luck.
Apr 16, 2014 | Kenmore Washing Machines
Washer fills up and goes through the wash cycle but stops when it is ready to enter the rinse cycle and will not drain
Check your lid switch. They are the number one culprit for this problem. When you open and close the lid, you should here a click from the switch.
Nov 21, 2010 | Kenmore 24032\24036 Top Load Washer
Kennmore elite model #110 just buzzes
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com.
If you need further assistance, please post back with a complete model number so that I may be able to assist you better. I hope this helps you.
Aug 16, 2009 | Kenmore 24032\24036 Top Load Washer
Stuck on rinse cycle
Often what appears to be a significant problem, may be something simple. I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
Aug 15, 2009 | Kenmore 24032\24036 Top Load Washer
Machine stops mid cycle it will fill and agitate then stop
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you still have questions, please let me know. I hope this helps you.
Jul 29, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Kenmore Elite 24952 topload washer stops after rinse before drain
sounds like lid switch ..if switch is along right side of of opening try holding it down with pencil or other slinder object if spins ok replace switch if switch is not visible it may be under left rear hinge area ck hinge screws and tighten or try pushing hinge lever toward back slightly
Nov 26, 2008 | Kenmore Washing Machines
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
137 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
