Service manual of Rafd 036jas - Heating & Cooling
I nedd termostat wire diagram for this esplit system urfb-036jas
All thermostat wiring is the same except some small differences with heat pumps, but try this
Nov 18, 2013 | Ruud Heating & Cooling
I came home house was hot went outside to check unit and fan wasn't running and smelled hot. My model # uacc-036jas. Is this a simple do it yourself fix or do I need to call service person
no fan was compressor running is there air coming out the vents ? do you know what a contactor is manuallly press it check the nreaker. 2 breakers one for airhandler one for condensor...
Sep 22, 2010 | Ruud Heating & Cooling
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
I have a Ruud Model UAFD-036JAS Air Achiever 9 split system. Does the outside unit have a reset button?The breakers are on yet no action from fan. Please help.
You have a blown or two blown fuses that will need to be replaced on the emergency shut off next to your condensor outside.
Jun 07, 2010 | Heating & Cooling
Rheem raka 036jas
This is not a stuck TXV.
If you have a AC and not a heat pump you have bad valves in the compressor and it will have to be replaced.
Aug 05, 2009 | Ruud Central System Air Conditioner
How do you remove the housing to access the coils for cleaning on a Rheem RACC-036JAS?
not completely just the fan assembly and wash from inside out only in extreme cases do you remove entire housing
Jun 22, 2009 | Heating & Cooling
Which service port is low side
The large line connected to the condensing unit wouldn't try add freon unless you know what you are doing get a licensed tec. could tell you how but it will cost $. Tom
Jun 19, 2009 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
