Question about Kitchen Ranges
Ultraline professional range self
How do you change the oven light. We can seem to remove the glass over over the light bulb.
bigg t
  • 640 Answers
SOURCE: broken glass light cover...
you should be able to use the unit without a problem,in between the panels where the light is theres insulation.you can try northernparts.com they may have a replacement cover for your unit.
Posted on Dec 26, 2007
SOURCE: changing oven light bulb
The manual states to turn the cover counter clockwise. I was able to turn it about an inch and then it stopped turning. You really have to apply pressure, but it will turn more. It is similar to a tight light fixture. I was worried about breaking it, but it did finally loosen. I believe the replacement bulb is a 40 watt mini oven bulb also...
Hope this helps!
Posted on Nov 29, 2008
SOURCE: gravy spilled between the glass on the oven door
how to take off the front door
Posted on Feb 15, 2009
SOURCE: Clean Oven Door Glass
Using a long stick/tool, attach a cloth to the end. Remove the drawer and look up at the oven door. There are 2- 3 openings that are big enough for you to reach the mess. Make sure that whatever you are using to clean the glass will not stay stuck inside, so make sure its attached securely. I used the end of back scratcher with a thin cloth attached to it. After a few attempts, I was able to completely remove the stain that was caught between the two panels. AND... I didn't need to remove any screws or dismantle the door. This could void your warranty.
Posted on Feb 17, 2009
SOURCE: oven light
Turn the power off to the oven. Spray around the bulb base / socket with Pam or similar spray cooking oil. Will take several applications. Bulb should free up -- may take a couple of hours for oil to seep into socket far enough to loosen it. Use oil liberally.
Posted on Apr 30, 2009
How do i change the oven bulb in jer8885qas
I hope this may help you if it doesnt have visible screwss etc.
Sometimes the glass lenses are held in place by clips behind them which are not visible.
I am not familiar with your machine but I suspect the lens in thick glass and is slightly 'proud' of the oven side.
You have to have faith that it wont break it, but you have to CAREFULLY lever the lens out of its fitting using something like a blunt screwdriver. Once you get one side started, you will get the idea. The bulb is right behind it.
Sep 15, 2014 | Jenn-Air JER8885QA Electric Kitchen Range
How do you change the oven lightbulb?
Most require 2 screws to be removed to lift the glass cover from over the bulb. Then simply unscrew the bulb and insert new bulb. A 1/4" nut driver is the best tool for the job.
Sep 08, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
Jan 11, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
How do you get the glass cover off to change the light bulb in the oven?
There is usually a snap on wire over the top of the light lens. Gently push down on that wire.
Jan 01, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
How do I change the light bulb in the amana range
You change from inside of oven. Bulb will be located under glass bulb cover. Push clip to side, remove glass cover, then unscrew bulb.
Jun 16, 2009 | Amana ACF3325 Gas Kitchen Range
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Oven light exploded and seems fused in socket
I was able to remove the base from the socket by inserting pliers and opening them so that they pressed against the inner sides of the base and then turning while exerting pressure.
Nov 12, 2008 | Whirlpool RF369LXPQ Electric Kitchen Range
LG LRE30451SW range
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
Jul 19, 2008 | LG LRE30451ST Electric Kitchen Range
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
