Question about Asrock K7S41 Motherboard
Powers on for a second and shuts down
I purchased this board because of its price and was compatible with my CPU. I'm using AMD 2400+. I've installed the MB, set the jumpers, connected the cables and turn it on. CPU fan spins for about a second, No beeps. I've used a diferent PS which I know is good, same result. Before installing this board my comp was not restarting easily (had to unplug and wait a while) to restart. It finally wouldn't restart at all. I am wondering if CPU could cause this problem. I would greatly appreciate any help.
    Scholar:
  • 113 Answers
Powers on for a second and shuts down - 6ce1e4e.jpgManual:
http://72.14.253.104/search?q=cache:rM03zfMddCsJ:ftp://download.asrock.com/manual/K7S41GX.pdf+Asrock+K7S41+Motherboard+manual&hl=en&ct=clnk&cd=2&gl=au
i am getting you this manual cause you can check what i am about to tell you here. make sure the jumper plugs are on the correct pins and that the BIOS settings match the configuration you have and especially make sure the power,reset,led,led2,powersw,speaker,sys pins that come from the power button and so on are over the correct pins on the motherboard!
good luck!
Posted on Oct 10, 2007
My hp a 1410n desktop powers up but shuts down after five seconds
#1 on the list for this is shut down from over heat due to CPU fan not running or CPU overheat. Check to see if your CPU fan is turning on when your system is powering up. If its not.. thats your problem (get a new fan)... Even if it is it could mean the fan is not properly contacting the CPU with thermal paste. If this is the first time you\'ve powered the system up, your next step is to go out and get some thermal paste and put it under the CPU fan, if you\'ve been running the system and this problem just cropped up.. skip the thermal paste, its already there. #2 Next possibility is BIOs power settings are incompatible with your hardware. For example the frequency on the CPU is set higher then it can operate and its over heating. Some systems will automatically shut down and restart with default settings others you have to get into and set to default. can you get into BIOS? Can you reset your BIOS settings to defaults? Check your mother board manual. #3 A compenent is shorting out your system and needs to be replaced. Is the system posting prior to shutdown (beeping once on start up?) If its beeping more then once that means something else and you should read your manual. If its not beeping then its a short somewhere and you can bet you have a bad part in the system. To identify which part it is you can either disconnect things (RAM, Drives, vid card, PCI cards,ect) one at a time, attempting to start the system after each one or you can take everything but the bare bones out and try to start it. I usually take all the RAM out but one stick and start by testing them. Your RAM is the most likely place for a problem in this situation. #4 If you\'ve striped it down and it still can\'t get a boot (with no post beep). You need to replace the mother board.
Jan 18, 2014 | Computers & Internet
My acer Keeps shutting down Could it just be dirty or do need to upgrade the power supply
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 18, 2012 | Acer Black AX3400G-U4802 Desktop PC with...
I just did a complete new build of a computer using the Elitegroup ECS A885GM-A2 board. It powers on, shows an LED on the board, but does not beep and there is no display whatsoever. All the fans ar
usually this means that the board is powered on, but that the cpu hasn't been initialized. make sure your cpu pins are clean of thermal grease and that it is properly seated. make sure your board is compatible with the cpu and if you can get a spare (known good) cpu to boot the board with, see if it starts, and see if you can update the bios.
again, basically the issue is CPU related. at some point you may have to just RMA the processor since it is a possibility that it might be DOA. good luck!
Feb 17, 2012 | EliteGroup ECS A885GM-A2 (V1.1) AM3 AMD...
My computer powers up for 1 sec then shuts off its using a intel dg41cn mother board i diconnected and removed all hdwr except cpu and it will run steady and post a 3 beep bio i then installed the grafix...
Gd morning
O.k are you building a new system...the memory you are using is it the original memory,if so try a new stick or try it in a different bank..
Is the memory compatable with the motherboard i.e the memory you should be using is DDR...
how big is the memory...
Try this link
http://www.intel.com/p/en_US/support/highlights/dsktpboards/dg41cn
Hope this help....please rate this as i,ve taken the time and trouble to help...if i can be any more help..
Regards
Apr 03, 2011 | Computers & Internet
5 socket mother board using 2800+ processor failed. Can i get a compatible mother board.
yes you can! compatible motherboards are cheap and easy to find for the socket 754 design compatible with your cpu. with prices going from anywhere from ~$50-$80. great places to shop include frys electronics, newegg.com, amazon.com and tigerdirect.com. when something like this happens to you its always a good idea to consider upgrading your computer as well you can find cpu motherboard deals anywhere from $100 to $200 with a huge boost in computing power. if you choose to go this route make sure your ram will work on the motherboard you are considering. goodluck
Mar 05, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
Does anyone know if I am able to mount an AMD Athlon 64 X2 (3800+ Socket AM2) on the H8SMI-2 ?? For me it is not clear described on the website of Supermicro.
no, this board is only compatible with AMD Opteron 1000 Series AM2/AM3 Cpu's. This board is designed for a server environment, hence the use of the Opteron CPU which is primarily used for server systems. Your CPU is an Athlon series which is mainly for home/business use and will not work with this board.
Feb 17, 2011 | AMD H8SMi-2 Motherboard
My toshiba powers on for 30 seconds fans kick in then shuts down immediately help'' Already replaced motherboard, no ground problems
Probably shut down by thermal protection settings in the BIOS; either fan is insufficient or something wrong with board/CPU; if the problem existed across 2 boards, I'd have to expect you have a fried CPU. Get a used replacement at RePC.com (so you don't have a big $ investment in troubleshooting.) Alternatively suspect failed HD (boot from a CD or floppy, esp useful diagnostically if you can disconnect the drive). Here in Seattle "Seattle Laptop Recyclers" (or some variation on that name - Aurora Ave N.) will diagnose and repair for $35 plus parts... it might be cheapest to ship it to them. Not a laptop? RePC repair service is very reasonable (I don't work for either company.)
Apr 25, 2009 | Computers & Internet
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
Dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Feb 03, 2009 | Dell Dimension 2400 PC Desktop
Asrock K7S41 Motherboard Logo
299 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
