Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Error code 130 & 240 how do i fix this - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
  • 34 Answers
Rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
Posted on Aug 06, 2009
3 Suggested Answers
SOURCE:
SOURCE: Fisher Paykel Washer IWL 12 error codes 130 & 240
Had the same problem cleaned the terminals worked for a bit and came back. The problem is that the little circit board that the plug goes onto that sits between the winding of the motor the copper tracks are so small and they corrode. If you are handly with a solding iron you can replace the tracks with small wire, its mainly on one leg of each of the transistors that are all parrelled up. You can tell because it goes black. Or the easy way just take off the motor unpluging the sense plug then the three main power connectors Yellow, blue and red making sure you mark the correct order to put them back on. The sensor board just pulls out of the windings with a little arrow to but it back in the right place and buy the small board it has the part number on it to find it on the web. I only has three bits on it can't be expensive. Soldered mine up works a treat make sur you clean up the plug aswell, it mainly played up in humid weather.
Posted on Dec 22, 2010
Jahn27
  • 1554 Answers
SOURCE: Intuitive ECO Model IW811 display
The fault codes 130 and 240 are pertaining to a Rotor Position Sensor problem. It is the part located wedged into the motor stator and it's sole function is the detection of motor functions particularly the rotor as the name suggests. The problem can be a simple loose wire harness or a damaged Rotor Position Sensor.
Unplug the machine. Tape the lid closed then lay the machine's front on a padded floor. Remove the single bolt holding the "plate-like" rotor to the shaft to access the Rotor Position Sensor. Once the rotor is off, check the contacts on the Rotor Position Sensor end of the wire harness to see if any have been damaged. Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Position Sensor harness. Consider replacing the Rotor Position Sensor if no issue is found with the harness and the connectors.
Posted on Jul 18, 2011
What is error 240 on a Fisher & Paykel IntuitiveEco IWL16 Top Load Washer
240. (11110000) Phase 6 - Hall Out of Order. RPS Fault
Same as previous Hall Error faults, just an extra fault code for Phase
6. See fault codes 130 and 131 for directions.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: 1. Check for corrosion on the edge connector of
the Rotor Position Sensor and the Motor
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
different contacts, replace the rotor positional
sensor harness.)
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S.
tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition.
Oct 02, 2012 | Fisher and Paykel IWL12 Top Load Washer
What is a code 240 and a code 130
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Jun 03, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel GW712 error code 130
this code imeans a faulty rotary position sensor and easy fix
Apr 21, 2012 | Fisher and Paykel Washing Machines
Intuitive ECO Model IW811 display error codes 240 and 130. what does this mean?
Jul 18, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Hi I have an approx 8 yr old F & P Intuitive Eco Washing Machine and I'm getting a 136 error message every few wash cycles. (well I've had it twice in about 8 washes) What does this...
Hi - check out this post - Code 130 - 136 all mean the same its a communication error between the sensors & the controller.
By mattnewmanha on Jun 16, 2011
I have a F&P MW512 top loader. It has developed a code 130. I have been told this is a faulty RPS. is this something I can fix at home? is there a bypass? how do I access and inspect the part?
Jun 19, 2011 | Fisher and Paykel (IWL12)
I need a code for my remote
Panasonic Universal Remote Code for TV/VCR
Admiral 200
Aiwa 180
Akai 014, 015, 016, 142
Audio Dynamic 011, 240
Bell & Howell 005. 013
Broksonic 081, 136
Canon 125, 135
Citizen 006
Craig 005, 006, 141
Curtis Mathes 130, 300
Daewoo 001, 130, 250
DBX 010, 011, 240
Dimensia 300
Emerson 003, 080, 081, 135, 136, 243, 250
Fisher 005, 007, 008, 009
Funai 081, 136
GE 130, 170, 300
Goldstar 006
Hitachi 000, 125, 300
Instant Replay 125, 130
Jensen 240
JVC 010, 011, 190, 240
Kenwood 006, 010, 011, 240
LXI 000, 005, 006, 007, 008, 009
Magnavox 125, 130, 150
Marantz 010, 011, 240
Marta 006
Memorex 009, 130
MGA 230, 241, 242, 243, 330, 340
Minolta 000, 300
Mitsubishi 230, 241, 242, 243, 330, 340
Multitech 004, 330
NEC 010, 011, 190, 240
Olympic 125, 130
Optimus 006, 100, 140, 200
Orion 081, 136
Panasonic 100, 101, 125, 130
J.C. Penney 000, 005, 010, 011, 130, 240, 300
Pentax 000, 011, 300
Philco 081, 125, 130, 136, 150
Philips 125, 130, 150
Pioneer 125
Proscan 000, 001, 002, 125, 130, 150, 300,
310
Quasar 100, 101, 125, 130
Radio Shack 005, 009, 130, 170, 210, 241
RCA 000, 001, 002, 125, 130, 150, 170,
300, 310
Realistic 005, 009, 130, 210, 241
Samsung 002, 004, 220
Sansui 081, 136, 240, 520
Sanyo 005, 009
Scott 001, 002, 004, 009, 081,136, 230,
241, 330, 340
Sears 000, 005, 006, 007,008
Shintom 050
Sharp 200, 210
Signature 2000 200
Sony 140, 141, 142
Sylvania 125, 130, 150
Tashiro 006
Tatung 010, 011, 240
Teac 010, 011, 240
Technics 100, 101, 125, 130
Teknika 130
Toshiba 001, 310
Vector Research 011
Mont. Wards 006, 009, 200, 210, 290
Yamaha 005, 010, 011, 240
Zenith 290
Codes for Cable Box
Puser 544
RCA 170
Realistic 544
Regal 130, 350, 720, 730, 731, 900
Regency 560
Rembrandt 005, 544, 702
Samsung 005
Scientific Atlanta 122, 130, 131
Slmark 001, 005
Sprucer 005, 121
Stargate 005, 544
Teleview 001, 005
Texscan 810
Tocom 700, 701
Toshiba 004
Unika 531, 544
Universal 522, 544
Videoway 006
Viewstar 541, 542
Zenith 000, 280
Zenith / Drake
Satellite
ABC 530
Archer 531, 544
Cableview 005, 544
Citizen 005, 522
Curtis 130, 131
Diamond 530, 531, 544
Eagle 541
Eastern 560
GC Brand 005, 544
Gemini 522
General
Instrument/
Jerrold
122, 360, 520, 521, 522, 530, 531,
532, 533
Hamlin 130, 350, 720, 730, 731, 900
Hitachi 003, 530
Macom 003, 004, 005
Memorex 542
Movietime 005, 544
Oak 002, 702, 710
Panasonic 120, 121, 132
Philips 006, 007, 540, 541, 542
Pioneer 001, 260
Pulsar 005, 544
Codes for Laser Disc
Panasonic 200, 201, 235, 380
Pioneer 370
Sony 240, 241, 242, 243
Codes for DVD
Denon 100
Ferguson 110
Nordmende 110
Mitsubishi 150
Panasonic 100
Pioneer 120
RCA/Proscan 110
Saba 110
Sony 140
Thomson 110
Toshiba 130
Yamaha 100
Zenith 151
Codes for Cassette Deck
Aiwa 760, 761, 762
Denon 800
Fisher 603
Jensen 657
JVC 780, 781
Kenwood 600, 650
Marantz 751
Nakamichi 631
Onkyo 651, 652, 656
Panasonic 700, 730Philips 751
Pioneer 630
RCA 763, 770, 771
Sansui 631, 653
Sharp 800
Sony 740
Teac 653, 654, 658
Technics 700, 730
Yamaha 601, 602
Mar 06, 2011 | Panasonic Televison & Video
Intuitive eco w.machine showing error code 130 and sometimes 240
switch the power off for a little while minute or 2 & turn it back on and press the power button and pstart the cycle again.
Apr 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Nov 04, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
8,783 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
