Question about Garden
Need new carburetor
I have a Honda F210 tiller that apparently has a worn out carburetor. I had a mechanic do a carb kit and he said the carb body is in poor shape. It runs but not well. The engine serial # is GV100-2157314 FY1*
The carb serial # as best as I can read it is 05 ACRA F???. Need to find a new one ..
  • 86 Answers
I will check to see if I can get you one at a resonable price.
Posted on May 13, 2009
Fuel is running through carb flooding out when pulling to start
The float valve is stuck open. It's time to rebuild the carburetor.
Jul 12, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Problem with a tiller Earthquake viper engine either the carburator or carburator gaskets LBLSNMC43
The Viper Engine is a Honda clone. Try a new carb for $15 0n ebay. http://www.ebay.com/itm/NEW-GX160-5-5HP-HONDA-ADJUSTABLE-CARBURETOR-WITH-FREE-GASKETS/121225345625?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30002%26meid%3Df495007fc18649159ceb1009031e4fad%26pid%3D100011%26rk%3D2%26rkt%3D10%26mehot%3Dpp%26sd%3D261393057447
Mar 04, 2013 | Ardisam Inc Earthquake Mini Cultivator
Pull starter honda f210 rope has come off
remove the starter cover whined the spool in the opposite direction that the rope pulls out hold it into place with a knot on one end feed the other end threw and out threw the opening pull it threw and tie on the pull handle
Aug 18, 2012 | Honda Clutch Cable F200 F210 F260 Tiller
My tiller only starts when I pore gas into the carberator air inlet. Then it surges for a couple of seconds and cuts off
IF THE TILLER HAS BEEN SITTING A WHILE I WOULD CLEAN THE CARBERATOR SOUNDS LIKE GUM BUILD UP. I HAVE HAD LUCK WITH DRAINING ALL THE OLD GAS AND DUMPING CARB CLEANER IN THE TANK WITH GAS AND KEEP TRYING TO START SOME TIMES THE CLEANER WILL DO ITS NJOB AND CLEAN THE GUM OUT OF THE PORTS IN THE CARB
Oct 12, 2009 | Troy-Bilt Pony Garden Tiller
Having carburetor problem with honda f210 tiller and it won't stay started
I need the year make and model. This sounds like you just need to adjust the idle screw or clean the carb with some carb cleaner and it should be good to go
May 16, 2009 | Honda Garden
Honda f210 tiller leaks gas when not running. if you leave the gas valve on it leaks on the floor. if you start it you have to regulate the amount of gas going into it, or it will flood out. it runs rough...
yes that's the problem.float level...you remove the float bowl and bend the float until it is at the factory specs.get you a manual and it will tell you the float height.if it says 4/32 you get you a 4/32 drill bit.put *** under the float chamber and bend until the bottom of the float touches the bit.
Apr 29, 2009 | Garden
Runs rough, leaking gas from carb when off craftsman tiller
Needs a carb kit. Go to any small engine repair shop or to a sears outlet store that has a good craftsman parts section. They will sell you a carb kit for around $20 bucks.
Your carb most likely needs a new needle valve and the float adjusted. There is a good chance that there is **** in the bowl as well. These carbs are easily rebuilt and it should only take you about 1 hour to put a new kit in it. Everything you need will be in the kit. If you need further assistance. Go into google and search for tech information for that carb. The name will be on the bowl or on the side of the carb body.
I hope this helps
Regards
VTX Guy
Mar 10, 2009 | Craftsman Rear Mount Tiller
Garden Logo
353 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
