How do you connect a pioneer VSX-523-k to a samsung led tv model un32eh4003vxza so I get audio fro the tv through the receiver to the speakers.
SOURCE: Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
Magnetic phono cartridges like the one on your pioneer has an output of about .005 Volts, the standard inputs are looking for 1 to 2 volts for fulol out put, the phono preamp will step up the output voltage to 1 volt so you can play it thru a non phono input like Aux, tape or tuner.
Radio shack sells cheap ones and you will hear what you pay for.
I sell turntables and audio gear, check out www.soundsciencecat.com
Good Luck,
Neal Van Berg
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
SOURCE: No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
SOURCE: I have a motorolla DSR505 sattelite receiver that
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
SOURCE: Have a Pioneer VSX-1018 receiver. When I connect
You speakers are out of phase. Check to see if the polarity is correct on the receiver and the speaker. Positive (red) with positive, negative with negative (black). Also check the impedance of the speaker, it should be located on the back of the speaker measured in ohms. Make sure that your receiver matches the impedance of your speaker. You can find this in the settings of the receiver.
