Question about Acer Aspire T135 PC Desktop
Boot configuration how do I fix missing file : \bcd error code :oxc oooo34
2 Suggested Answers
myob247
  • 1342 Answers
SOURCE: windows boot manager file: /boot/bcd status:
Here is Microsoft's resolution
Posted on Apr 29, 2008
HP Color Laserjet 5550dn printer connected in network configured through server, showing error 0xc0000005 while clicking on printer properties in any client system?
You have hacked or infected files on your computer.
Check your BCD and do the below fix if necessary (at your own risk)
In Windows open CMD as Administrator and type BCDEdit and enter, if your Windows Boot Loader Path is xOsload.exe then you need to remove some files and repair your BCD.
NOTE: you will need to re-activate Windows afterwards, so make sure you have your Windows 7 key handy.
Boot to Windows Repair - Command
Del D:\Windows\System32\xOsload.exe
Del D:\Windows\System32\xNtKrnl.exe
Del D:\Windows\System32\Drivers\oem-drv64.sys
attrib c:\boot\bcd -h -r -s
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
Oct 14, 2016 | HP Office Equipment & Supplies
How can I fix a windows failed to start problem? what is a file : \Boot\BCD STATUS : 0XC000000f?
Try F8 and safe mode or if that doesn't work, insert your OS disc and try to repair your OS, then check the hdd for errors, if it is not too late!
Aug 12, 2014 | HP Computers & Internet
Acer Aspire 5600u I need CD recovery disk
Have you checked here to see if what you need is here?
Drivers and Manuals
Jul 30, 2014 | Acer Computers & Internet
BOOTMGR is missing,
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Check your optical drives, USB Ports, and floppy drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable disc, external drive, or floppy disk.
  3. Reseat all internal data and power cables. BOOTMGR error messages could be caused by unplugged, loose, or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  4. Perform a Startup Repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR.
    Even though a Startup Repair is a common solution for BOOTMGR problems, don't worry if it doesn't fix your problem. Just continue troubleshooting - something will work.
  5. Write a new partition boot sector to the Windows system partition to correct any possible corruption, configuration problem, or other damage.
    The partition boot sector is an important piece in the boot process so if there's any issue with it, you'll see problems like "BOOTMGR is Missing" errors.
  6. Rebuild the Boot Configuration Data (BCD). Similar to the partition boot sector, a corrupted or incorrectly configured BCD could cause BOOTMGR error messages.
    Important: The following troubleshooting steps are much less likely to help fix your BOOTMGR problem. If you've skipped any of the above ideas then you may have overlooked a very likely solution to this problem!
  7. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  8. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, please understand that you will lose them all if you continue with a clean installation of Windows!
  9. Replace the hard drive and then install a new copy of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
SysFlashwww.sysflash.com
May 29, 2013 | Lenovo IdeaPad S10-3t 0651 Notebook
Accer aspire 5715z problem file boot/bcd
It seems that the Boot Configuration Data (BCD) is corrupted.
Microsoft has completely reengineered the boot environment for Microsoft Windows Vista to address the increasing complexity and diversity of modern hardware and firmware. One aspect of this reengineering is a new firmware-independent data store that contains configuration data that influences the boot process. This paper provides an overview of this configuration data - called boot configuration data (BCD) - and describes how to use the related tools to manage boot options.
Step 1
Perform chkdsk which will repair the bad sectors of the hard drive.
To do this, follow these steps:
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator.
2. Type chkdsk/ f, chkdsk/r, chkdsk/i, chkdsk/c in the commands listed below i.e. (/f, /r , /i, /c).
Step 2
Try to load BIOS to default and check if you have similar issue.
Step 3
I would suggest you to rebuilt BCD. To do this, follow these steps:
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  1. Put the Windows Vista or Windows 7 installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. In the System Recovery Options dialog box, click Command Prompt.
  7. Type Bootrec.exe, and then press ENTER.
8. Type bootrec /RebuildBcd , and press Enter.
Aug 06, 2012 | Computers & Internet
What is file error 0xc000000e
File: \Boot\BCD
Status: 0xc000000e
Info: An error occurred while attempting to read the boot configuration data.
Windows Boot Manager
Windows failed to start. A recent hardware or software change might be the
cause. To fix the problem:
1. Insert your Windows Installation disc and restart your computer.
2. Choose your language settings and then click "Next"
3. Click "Repair your computer"
If you do not have this disc, contact your system administrator or computer
manufacturer for assistance.
ERNZ
Feb 03, 2010 | Toshiba Sattelite A105-S2051 Notebook
Missing file: \windows\system32\winload.exe
Boot from your Operating System CD and do a Repair. This should solve your problem.
or
To fix this issue next time, boot Operating System, F8, select Command Prompt, type the following (anything inside the parens is a comment):
C: (assumes the C drive is the default)
CD Boot
Dir
(look to see if the BCD file is missing - it probably is.)
Bootrec /rebuildbcd
(Let the script run and it should rebuild the BCD and the issue should be resolved)
Sep 14, 2009 | HP Pavilion a1700n PC Desktop
Acer Aspire T135 PC Desktop Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
