Question about Riccar 1500. 1700, 1800, Pristine, Starbright, Charisma Canister Filter Vacuum Bag Antimicrobal 6
Busted fuse on riccar pristine - Riccar 1500. 1700, 1800, Pristine, Starbright, Charisma Canister Filter Vacuum Bag Antimicrobal 6
I purchased a riccar 2150L second hand with no information. I have a 10yr old riccar supralite and love it! But the 2150L looks older. I am curious what the age of riccar 2150L vacuum is.
Your m
2150 L is likely 25 to 30 years old. The first Riccar vacuums were made in Japan. Your was likely made in Taiwan. Production of most models was brought to St. James, MO 20 years ago. Filters, bags and some parts are still available from your local Riccar dealer, or from ThatVacGuy.com
Dec 14, 2017 | Riccar Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
What size replacement belt for riccar 1700 vacuum
You need to contact your local Riccar dealer. They are not available except from Riccar dealers.
www.riccar.com
Sorry.
May 30, 2014 | Riccar 3623210300 RC 1700, 1800 Full Size...
Is there a reset button
The reset button is internal. If it overheats it will shut off but will come back on when it cools down. This usually means you have a clog somewhere or a clogged bag or filter. If that doesn't take care of it have it checked by your Riccar dealer.
Mar 30, 2014 | Riccar 1500. 1700, 1800, Pristine,...
Riccar vacuum Moon 1 just won't turn on, any ideas?
Check cord, esp at entry point. Otherwise it may be switch, motor windings burnt out, broken wire, carbon brushes worn. Some appliances also have a thermal fuse, which is a silver tube shape.
Apr 13, 2013 | Riccar Moon, Pazza Vacuum Cleaner...
Suction not working
If suction is good at the canister but not at the end of the hose you must have a clog in the hose
Jan 02, 2013 | Riccar Generic 1400 1500 1700 1800...
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
May 22, 2010 | Riccar 8850 Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at chris.jones@govacuum.com.
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Riccar 1500p vacuum won't start
it has a thermal fuse that shuts it down if it over heats. Check the hose , wands and floor tool for blockage and check your bag and filters as well.
Oct 01, 2008 | Vacuums
Riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at drago640@yahoo.com subject riccar, or go to www.riccar.com to locate nearest dealer
Mar 22, 2008 | Riccar RC1100 Compact Vacuum
Riccar 1500. 1700, 1800, Pristine, Starbright, Charisma Canister Filter Vacuum Bag Antimicrobal 6 Logo
66 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
